Dual Feed line from II
Old 01-05-2007, 06:24 AM
dodgeboy59td's Avatar
Does this really help much???
Old 01-05-2007, 11:26 AM
jlibert's Avatar
If you're running 500+ hp, yes.
Old 01-05-2007, 12:12 PM
Like how much? a big difference? im running 540 hp?
Old 01-05-2007, 01:26 PM
jlibert's Avatar
well, on my truck I was able to turn the tst up 1 additional setting. Worth it imo
Old 01-05-2007, 02:23 PM
what does it hook up to and how?
Old 01-05-2007, 04:16 PM
jlibert's Avatar
hooks up to back of cp3, and takes the place of the pressure relief valve in the rail.
Old 01-05-2007, 05:10 PM
do you jus leave the return hanging like that?
Old 01-06-2007, 11:09 AM
jlibert's Avatar
yep. just like that. The day I installed it, I tried to block off the filter housing and the pump with a couple of cut down bolts(the other two spots that line runs to) and the truck wouldn't run. Hooked it back up the way you see it and it started right up. I don't care for it either, but that's the way industrial says to do it. I suppose you could run a better line from the housing to the pump and have it look cleaner.
Old 01-06-2007, 11:43 AM
t-boe's Avatar
Jlibert, how do you like your Silver 66? Do you have any surging issues?
streetsmoker
36
02-07-2008 07:16 PM
wap
18
04-12-2007 08:48 PM
powerstrokin03
02-15-2007 04:29 PM
EQUIPPRO
02-14-2007 09:04 PM
Quick Reply: Dual Feed line from II
