Dual Disc South Bend Clutch Won't Realease!
Old 02-24-2008, 12:41 PM
dalefans2's Avatar
I bought a South Bend 3250 Dual disc clutch from an individual. It will not release all the way. I purchased the heavy duty hyd. clutch system from South Bend and no help. The slave rod doesn't seem long enough to release all the way. Any suggestions?
Old 02-24-2008, 12:44 PM
busa's Avatar
Did you adjust your slave rod? The South Bend unit has some adjustment. Also if to much meat was machined off the flywheel it can cause this too.
Old 02-24-2008, 01:05 PM
dalefans2's Avatar
Busa, I used the flywheel that came with it and it has the replaceable button pads installed instead of machining. The slave rod is non adjustable where as the master rod is adjustable and it mainly moves the clutch pedal closer to you. The slave rod sure needs to be adjustable. Thanks
Old 02-24-2008, 01:33 PM
ILLINOISRAM's Avatar
Just curios, but what exactly do you mean by it wont release. I bought a new dd clutch from Kenny's pullin parts and from nuetral, it would not go into gear worth a hoot. Sent it back to him and he machined the floater to give more release room. This helped but did not fix. Truck would go into gear but would start to move truck. I then added SBC hydro and still didn't fix it. It turned out to be one that the springs were wrong and coil binding and that the friction disc were not true causing drag. This might be your issue.
Old 02-24-2008, 04:15 PM
stuckey200224's Avatar
the fingers on the clutch plate may need adjusted
Old 02-24-2008, 06:14 PM
J Lent's Avatar
Did you remove the washer on the clutch release fork pivot ball stud? Try adjusting the clutch pedal rod where it attaches to the clutch pedal. Then you could take the slave cylinder out of the bellhousing & remove the spacer on the slave to give you some more pedal.
Old 02-24-2008, 07:54 PM
William12Valve's Avatar
You can try replacing the pivot stud. this made all the difference in the world on my try. The old one was worn a good 3/16 of an inch.
Old 02-25-2008, 07:32 PM
afoulk's Avatar
You don't have one or both of the clutch discs in backwards do you? If you would get them in backwards, the disc hub could make contact with the flywheel or pressure plate, not allowing the clutch to fully release.
Old 02-25-2008, 07:41 PM
killed300ex's Avatar
willing to bet that is your problem. When I did my 5 spd swap I did the same thing caused the exact same problem. Id call southbend and talk to them they will talk you through the right way to install the disks. Very stand up peole and willing to talk with you to make it work right.
Evan
Old 02-27-2008, 02:13 PM
dalefans2's Avatar
Guys, I have tried everything. Talked with SBC and went ahead and pulled the clutch and everything was in correct. I am taking it up to SBC tommorrow and let them go through it. I am at a lost. I will let you all know what I find out or what I decided to do. Thanks, Bill
Old 02-27-2008, 02:21 PM
Admin Team Leader
Lary Ellis (Top)'s Avatar
Have no fear....Peter has an OUTSTANDING reputation in the Diesel performance business because he earned it, one clutch at a time and one customer at a time.
They will get to the root of the problem and have you grinning in no time
Old 02-27-2008, 02:52 PM
J Lent's Avatar
That is true, you are in good hands. Peter will make you
Old 02-27-2008, 07:45 PM
afoulk's Avatar
I read over Larry's post to fast the first time and I thought he said " They will get to the root of the problem and have you "GRINDING" in no time." I hope thats not the case
Old 02-27-2008, 08:44 PM
Admin Team Leader
That just happens with that "Other" company that is selling those junk Chinese products
Old 02-27-2008, 08:51 PM
dodgezilla04's Avatar
peter will do whatever he can to support someone with his clutches. its amazing
Quick Reply: Dual Disc South Bend Clutch Won't Realease!
