dual climate control AC
questions guys. i have a 05 quad cab with the dual climate control.
the ac on the DRIVERS SIDE IS VERY COLD ,THE PASS SIDE IS NOT VERY COLD..
DID ANYONE ELSE HAVE THIS PROBLEM? HOW DID YOU FIX IT?
THANKS IN ADAVANCE.
MARK
JTSKIR222@AOL.COM
THANKS IN ADAVANCE.
MARK
JTSKIR222@AOL.COM
I have a 06 without the duel climate control. drivers side is cool and the two vents on the passenger side are definately warmer. my wife keep giving me 3 degree cause I keep telling her it's her imagination. Does anyone know why
the drivers is cooler ? was it made to keep just the driver cool? I had the blend door replaced once, when the door broke no air came out of any vents
but I could hear the blower turning at all the different speeds.
Had my Mega Cab in 8 times last year A/C problems, recirc door and 10-20 degree spread between the vents. The factory rep came up 340 miles to look at my "strange" problem. I had digital thermometers clipped in all the dash vents for his inspection! My truck has dual zones also.
They dumped/recharged the system twice and got the spread down to 10 degrees. The factory rep stated a 12-14 degree spread is acceptable, not much luck cooling on 100+ degrees days in CA.
The A/C on the trucks is poor when faced with any temps above 90 degrees.
Silverbullet06
Silverbullet06
SolarYellow05
06-22-2006 04:55 PM
RobG
12-20-2005 01:28 PM
grizzly660fan
01-02-2004 10:02 AM
BamBam
05-10-2003 08:50 PM
