dual air cleaners
Old 03-28-2004, 03:01 PM
linetrash75's Avatar
dual air cleaners
anybody have an extra air filter box they want to get rid of i'm thinking of fabing dual air cleaners. move passenger side batt to driver and place second air cleaner there make a y-pipe, double air flow. let me know if you've donethis are have any ideas. dont want a k&n or afe to pricey and i dont believe they filter as well, also dont want bhaf.
thanks jed
Old 03-28-2004, 04:15 PM
I don't have a filter box for you, but I think you have a good idea. You might want to ask the 12 valve guys as well, they have the same filter box. I haven't heard of anybody doing this before, let us know if it works out well for you. What sort of plumbing were you planning on using?
Old 03-28-2004, 04:17 PM
Administrator / Scooter Bum
Shovelhead's Avatar
That's alot of weight to transfer from one side of the front end and add to the other.
I would think an aftermarket air cleaner system would be less involved, more functional, and possibly less expensive.
Ed
Old 03-28-2004, 04:23 PM
Mexstan's Avatar
Not sure why you would want to do this but pardon me if I disagree with your idea. I suspect that in reality the air will tend to go thru the easiest route. In all probability only one air filter will work at a time. I cannot see that you will end up with cleaner air. At the most, depending on your plumbing and pipe diameters you may have a slight gain in airflow but the increased airflow will probably be so minimal that the engine will not produce any more noticeable power.
Scotty could perhaps answer this better then me.
Old 03-28-2004, 04:35 PM
not worried about weight side to side no different than somebody weighting 300lbs driving my truck. dont want aftermarket havent seen anything better than factory box for filtering, its just dont move the air. stock boxes stay queit, more water resistant than open filter, pull cool air from inside fender, andfilter better. still need a second air cleaner.
was tinking one ss 4'' y pipe and some hose clamps not expense at all .
i know i wont get cleaner air just more of it. i like paper filter over foam or oiled cotton.
Old 03-28-2004, 07:03 PM
If you want real low buck plumbing use PVC pipe. Check out Merrick Cummings' photo album, that's what his intake plumbing is. I agree with you that paper filters better.
Old 03-28-2004, 07:07 PM
pvc didn't come to mind but it should wok fine do you know how i can get this to performance forum?
Old 03-28-2004, 07:10 PM
PM the forum moderator (Jack Thorpe on this forum) and ask him to move it. BTW, it's not Merrick Cummings who's got the PVC intake, it's J.R. Adkins.
Old 03-28-2004, 10:12 PM
joefarmer's Avatar
I have a stock air box (minus the hose). The filter got 900 miles on it (distance from the dealership to my house ). PM me if you want it.
brandon.
Old 03-29-2004, 01:07 AM
BigBlue's Avatar
I just put a Scotty 2 on mine and it's awesome. The Scotty 2 is by far the best intake on the market. With proven 150* EGT reductions, it's hard to beat. Just my OPINION.
u2cheyenne
02-12-2007 03:52 PM
lovinCTD59
12-01-2006 06:27 AM
jrs_dodge_diesel
11-25-2004 03:04 PM
CAPTDASH
10-29-2003 05:21 PM
Alan_Reagan
12-24-2002 09:38 AM
Quick Reply: dual air cleaners
