dss & steering
Old 04-28-2006, 06:50 AM
dugout's Avatar
Thumbs up dss & steering
I guess we are going to wear this subject out ,but here goes;
I bought this 01 2500 2wd/w 80000 mi good trk not abused,but it wanders in the steering like all the threads i have read got it checked out at front in shop everthing tight. installed a DSS,helped a lot ,ajusted gear box 1 turn in,to tight now.should i tighten the screw all the way in and back off a turn or 2? What is the proper adjustment ,I think dodge should recall this,it really stinks ,this steering reminds me of an old freightliner with air assist power steering that was bad, thanks for the space. dugout doug love that cummins.
Old 04-28-2006, 11:08 PM
artfulldodger's Avatar
Doug, For whatever it's worth...
Mine is an '01 4wd, had delay in input from day one. Tightened box aprox. 1/8 turn, noticable change!
Grilled tech @ alignment shop, he said small adjustments are best. Hope this helps.
Love my Cummins also, does mean we are having a three way?
Dave
Old 04-29-2006, 06:29 AM
dugout's Avatar
Dave
thanks dave I tried that and it do help.
Old 04-29-2006, 06:57 AM
Ironstone's Avatar
I just got a 95 and it wanders pretty bad too......I must look like im drunk goin down the road. Ill give it a 1/8 turn and see how it does
Old 04-29-2006, 07:59 AM
Dodge Demon's Avatar
Replace your "track bar". replace your "lower control arms" set your castor at "5+", its all on this site-www.solidsteel.biz
Old 04-29-2006, 08:00 AM
And another thing....
Ironstone, Doug,,
Thought of something else this AM.... Iron, have someone "rock" the steering wheel back and forth (with the motor off) while you watch/feel the movement between the steering shaft & the pitman arm-sector shaft.
The same basic thing as when checking tie rod ends etc.
Take care not to get your fingers pinched
Another thing, more of a related FYI. After installing the new tires/wheels had Dodger's toe caster, camber checked adjusted. Poor guy tried to set toein 6 or 7 times, would not keep setting. I suggestted doing adjustment WITH motor running. First time was all it took! Must have something to do with hyd. psi. against the centering ball?
Anyway,,, it worked. Might try that also.
Dave
barracuda
08-30-2005 10:56 AM
billmac
05-17-2005 05:37 PM
chasmack
03-21-2005 05:35 PM
fitzydog
32
03-12-2005 10:58 PM
06-05-2003 09:27 PM
Quick Reply: dss & steering
