Driveshaft help
Old 05-20-2008, 11:39 AM
Hopper's Avatar
Driveshaft help
Ok. Feeling like a tard here...
Trying to remove the rear driveshaft on my '03. I'm getting new u-joints, and I am having the driveshaft reballanced at a local shop to see if that will clear up some of the driveline vibrations.
I'm trying to figure out how to remove the rear driveshaft up near the transfer case. Does it just pull out of the transfer case? Never worked on this truck's driveline before, and have never seen a setup like this before either.
Old 05-20-2008, 02:43 PM
HOV
HOV's Avatar
Yeah, IIRC there are splines that couple it to the transfer case. Just pulls out once you've unbolted the axle end and the bracket.
Old 05-20-2008, 05:44 PM
Hopper's Avatar
Will I need to wory about AFT leakage, or are the splines sealed?
Old 05-21-2008, 01:10 PM
Aggie007's Avatar
No ATF leak, if so you have a bad seal.
Old 05-21-2008, 06:52 PM
Hopper's Avatar
Thanks. I try and remove that thing tomorrow. Wouldn't doubt I have a bad seal though, every freakin' thing else on that tranny leaks like screen door in a hurricane.
Old 05-21-2008, 11:15 PM
dieselkan's Avatar
Not sure about the auto trans but removing the drive shaft from a manual trans will allow the trans oil to leak out. I would assume an auto would be the same.
Erska
17
09-24-2010 12:35 PM
isbsinkinson
01-29-2008 04:19 PM
wvtruckpuller
09-12-2007 10:25 PM
Quick Reply: Driveshaft help
