Drivers side parking light
Old 05-11-2007, 03:29 PM
dodgedude361's Avatar
My drivers side parking light went out. After a quick peek, it looks like a hassle to get to. It is behind the fuse box. Can someone tell me how to get to it? Do I go from under the hood? or does the whole light assembly have to come out.
Any tips would be help full
Thanx
Old 05-11-2007, 08:21 PM
DiEseLjunKy's Avatar
You'll have to pull the headlight assembly out. There are three 10 mm bolts holding it in. Pop the hood and you will see 2 of them. The last one is inside the wheel well you will see an oval shaped rubber thing that can be pulled out (keeps water out of there) and stick your racthet through there. The headlight assembly can be a pain to get out of there but just be patient and work with it. Once you get it out you will see all you gotta do is unplug the harness and twist the bulb out easy as can be. It looks like a worse hassle than it really is. It's not. A 10 minute job tops for just about anyone. Hope it helped.
*edited* just noticed you have an '03 which is probaly somehwat different than the '06-'07 style. If it's not similar to mine just look in your manual for "lights" replacement it will tell you how to pull the headlight assembly out, or even if it needs to be done with an 03...
jmlcolorado
08-21-2013 10:44 PM
joem
04-10-2012 12:14 AM
BigBore050
03-09-2010 11:46 PM
Stovetop535
01-08-2010 12:47 PM
Quick Reply: Drivers side parking light
