driver side brake squeak
Old 11-15-2006, 10:50 PM
b.lee's Avatar
Question driver side brake squeak
it only happens when im going slow.
there are plently of pad left and the rotors are fine...
someone here said something about a silencer o-ring / brake pad spacers? does this ring a bell with anyone? anyone using them?
thanks.
Old 11-16-2006, 08:40 AM
DL1221's Avatar
Have you tried Anti Squeak from your local parts store? Its like a glue that allows you to glue your pads to your calipers, it is supposed to stop the vibrations which can cause squeak. It may help, even if you have built in shims in your pads. If the squeak stops when you apply the brakes, this is probably it.
Old 11-16-2006, 08:47 AM
b.lee's Avatar
cool, thanks for the info.
I will try that asap.
shep1
08-29-2010 10:19 PM
CTD2001
15
11-28-2009 07:54 PM
ytodd
11-02-2007 09:57 AM
gman07
05-09-2007 06:03 AM
hotdram
31
09-17-2005 08:00 AM
Quick Reply: driver side brake squeak
