Driveline vibration
Old 04-02-2007, 12:58 PM
Tocapet's Avatar
Driveline vibration
My truck has a high-speed vibration that shows up around
60 MPH. Annoying. Just had the diff gone through. New bearings & clutches in the limited slip. U-joints look OK, Carrier bearing doesn't move. Wondering what it could be???
Old 04-02-2007, 01:12 PM
PChouinard's Avatar
What kind of truck?
Wheel and tire out of round, balance? Maybe an ever so slightly bent driveshaft?
Dually? Check for rocks between tires...
Old 04-02-2007, 01:26 PM
Tocapet's Avatar
It's not a wheel-balance thing. That would be a low-speed vibration. I'm getting a high-speed vibration like a bad U-joint. Here's my sig. Sorry.
1999 SLT Laramie 2500 CTD. Quad-Cab Lwb, 175K, Auto, 2wd, 3.54s, 5" straight pipe, Vulcan kit, FP guage. Silencer ring?... Whuzzat?
Old 04-02-2007, 01:55 PM
Jerrod's Avatar
My carrier bearing didnt move either, but i changed it out and my high speed vibration quit
Old 04-02-2007, 05:54 PM
Tocapet's Avatar
How much did you pay for the bearing & where did you get it?
Old 04-02-2007, 09:14 PM
TNutcher's Avatar
double check u-joints. mine did the same thing and i missd the bad u-joint at frist check but sure enought . . . as it got worse the u-joint finnaly caught my eye. Whatever it is, if its fairly violent, fix it as soon as you can. I drove on mine for a week or two and a few months later when i was having my tranny suncoasted they found a case cracked between the tranny at trans case (dry shaft inside so no obvious leak but still 150$$)
TNutcher
Old 04-03-2007, 08:12 AM
Jerrod's Avatar
I got it from the dodge house, it was 150.00
Old 04-03-2007, 11:10 PM
Devin_01's Avatar
When i had a vibration all the u-joints were tight but when i took it down the road for about 30 miles i got out and checked them again and the one u-joint was really hot. I changed it out and it went away. Just another idea.
Old 04-04-2007, 08:47 AM
skyking's Avatar
I removed drivelines that everything looked fine. after removal I found one u-joint bearing full of metal dust from disintegrated bearings. Bad u-joints have been the vibration problem many times. Replace u-joints and it will probably go away.
Old 04-04-2007, 11:30 AM
Tocapet's Avatar
Wow!! I just bought a new support bearing from Autozone this morning for $15.99 plus tax. You must've had them install it and everything for that price.
Old 04-05-2007, 07:28 AM
Jerrod's Avatar
No I installed it. All the aftermarket parts houses around here are crap.
Old 04-05-2007, 06:13 PM
BRET LIVELY's Avatar
Napa C-bearing Is $ 98 And Change
How Easy Is It To Replace ?
Old 04-07-2007, 07:19 AM
Jerrod's Avatar
Its not bad at all to replace. Hardest part is driving the old bearing off the shaft and driving the new one back on. It took about an Hour
Old 04-07-2007, 07:46 AM
Tocapet's Avatar
Everyone says that bearing needs to be pressed. How did you drive it off and on without damaging it?
Old 04-07-2007, 08:14 AM
Jerrod's Avatar
To get the old one off, I put it in a vice and used a punch and hammer, hitting it all around until it came off. Then to put the new one on I used a piece of pipe the same size as the keeper and drove it on by hitting the pipe until i got it where i wanted it
Quick Reply: Driveline vibration
