Drive Pressure
Drive Pressure
Drive pressure is what actually destroys head gaskets, am I right?
I've also heard that boost pressure and drive pressure should be 1 to 1. So if your @ 1 to 1, what would be the safe upper limit of boost with a stock head gaskets and bolts? Where would you plug into to find drive pressure? I hope these are not dumb questions.
Pull your pyrometer probe temporarily.
1:1 is unusually good. Be happy if you can keep it under 1.5:1.
Drive pressure does not kill head gaskets, peak cylinder pressure kills head gaskets.
Try to keep your boost to 40 psi.
as dave said drive pressure isnt the problem w/ headgasket failure. a combo of hi boost+ advanced timing+ 17 to 20 yr old h.g. or any one of these is more often cause. smaller turbo is not neccecarily the problem either- keep turbo in its effeciency map its ok. hi drive pressure dooes sap power on top end.
2006BLKMegacab
07-03-2011 08:31 AM
cincydiesel
06-11-2008 01:55 PM
skymiles
12-21-2006 10:05 PM
Hummin Cummins
02-11-2003 12:14 PM
Copenhagenjunkie
12-27-2002 05:45 PM
