drill for pyro pre-or post turbo?
Old 08-12-2003, 07:45 PM
Mark Thomas's Avatar
which is better, and does the tubo have to come off to be drilled? ???
Old 08-13-2003, 09:22 AM
bulabula's Avatar
Re:drill for pyro pre-or post turbo?
Since you're concerned about heat (and too much of it), mounting it pre-turbo will give you a better indication of exhaust gas temps in the engine.
Mounting it post-turbo will allow some heat loss to occur in the turbo before your sensor, leading to a lower reading and possibly misleading information.
I don't think the turbo has to come off, but I would be concerned about metal shavings making their way into the turbo.
Old 08-13-2003, 06:49 PM
FiverBob's Avatar
Mark,
There have been some great discussions on this site about pyros, where to mount, why, etc. You would do well to run a Search and see what is there. Also, send a PM to Push Rod at www.wildcatdiesel.com *. He will guide you thru the process.
Bob
* edited to correct info
Old 08-14-2003, 08:28 AM
Badunit's Avatar
I mounted mine post-turbo because all I am concerned about right now is cool-down temperature of the turbo. Pre-turbo won't tell you as much about that. Someone made the analogy that pre-turbo is like monitoring the tip of the torch not the piece of metal it just heated up. I figure if I ever decide to do some bombs I can put a 1/4" plug in my post-turbo hole and drill a new hole in the manifold.
Brian08Q35004x4
02-01-2011 04:37 PM
mega_man
05-29-2008 03:40 PM
scottmn1
09-01-2004 01:40 PM
03racecarhauler
02-24-2004 12:18 AM
redram
12-10-2002 09:54 AM
Quick Reply: drill for pyro pre-or post turbo?
