DRC axle truss.. where can i buy one?
Old 03-31-2007, 07:44 PM
nfsommer's Avatar
I've decided i need this
where do i get one online?
Old 03-31-2007, 07:48 PM
Lsufan78's Avatar
where did you get the 5.13's for your axles??
sorry about being off-topic.
later, dustin
Old 03-31-2007, 07:49 PM
t-boe's Avatar
You need one, or just want one? I think you just buy them from Desert Racing Concepts themselves.
Old 03-31-2007, 07:50 PM
nfsommer's Avatar
accu auto parts, ask for jerry
800-869-7030
tell him nick sommer sent u, he knows me ive bought everything on my truck threw him
Old 03-31-2007, 07:51 PM
nfsommer's Avatar
i plan on jumping this truck at least 10 feet off the ground, i might need it
Old 03-31-2007, 07:52 PM
t-boe's Avatar
Do you have AAM axles?
Old 03-31-2007, 07:55 PM
nfsommer's Avatar
y
e
s
i
d
o
Old 03-31-2007, 08:02 PM
t-boe's Avatar
I just checked the website. Good place to remember.
Old 03-31-2007, 08:13 PM
Lsufan78's Avatar
well, that absolutely sucks...only up to 4.56's are available for the 10.50 (which i already knew), but 5.38's for the 11.50!! anybody wanna swap axles??
Old 03-31-2007, 08:19 PM
DirtEater's Avatar
DRC had a shop in San Diego do their trusses, at least Greg Boardman did, as well as Kroeker. I got their shops name through Boardman and went down to meet the owner quite awhile back. The shop is called Differential Systems and owned by Jason Hughes. (619) 298-3568. Hope this helps.
Old 03-31-2007, 08:22 PM
nfsommer's Avatar
/\ Thank You
Old 03-31-2007, 11:27 PM
gatf4's Avatar
You do need one, I bent my front axle housing on the first trip to the Silver lake Sand dunes in Michigan. The dealer had a hard tme figuring out why the front spiders gears kept getting torn up. I got a call from them asking if I was ever jumping my truck. I just told them "I didn't do anything that my top of the line 45k truck shouldn't handle". They replaced it under warranty. I found out from DRC that the front diff is a known weak point for serious off roading. I thought they Quouted me around $800 for laser cut steel parts that you weld onto your axle tubes and center section. Have fun, Ten feet in the air sounds cool.
Old 03-31-2007, 11:30 PM
Luvnacumns's Avatar
Pic's pleaseee. ... Video Preferred!!
Old 04-01-2007, 09:57 AM
ataboy9026's Avatar
Wow. $800 sounds pretty darn salty for that. It looks like you could get a piece of 2" x 6" x .250" thick mild steel (or even .125") and spend a few hours with some cardboard templates and some saw's/ grinders/ and a welder and there you have it. Even if you spend the money for the nice lazer cut parts I am sure it will need some "final fit grinding" done anyway. I am a pretty handy guy with all those tools though. But anyone with some safety glasses and a few hours could make that. If your not a welder find someone that is. And do little bits at a time as to not warp the axle from heat.
Old 04-01-2007, 03:34 PM
cquestad's Avatar
Make it...you have a steel shop IIRC?
Quick Reply: DRC axle truss.. where can i buy one?
