draining more qts of trans fluid
DRAINING more qts of trans fluid?? HOW
what ways are there two drain more than 7 qts of trans fluid out , before or after pulling pan , i would like to get most out if i can.
would some come out if i drained pan (i have b&m plug installed) put truck in neutral and cranked truck over without truck starting, would that circulate more to the pan.
thanks for the ideas
Do a search, there are a couple posts on this topic. When I changed my fluid, I dropped the pan and changed the filter. Added 6 qts and pulled the return line at the tranny. Ran a hose into a 5 gal bucket, started it up and put it in nuetral. Pumped about 5 qts (watched for it to start slowing down), shut it down and added the same amount I pumped out. Ended up changing about 14 qts when the fluid pumping out started looking nice and clean.
Most say just drop the pan, but I can tell you my tranny is shifting smoother and not getting as hot by changing more than 6 or 7 qts. It was super easy and did not add more than 10 minutes time vs just dropping the pan.
thaimonkee
03-03-2011 04:00 PM
smokinram99
01-06-2009 09:00 AM
03CTDCO
02-22-2005 11:46 AM
