drain valve????
Old 02-24-2010, 06:00 PM
sotex's Avatar
drain valve????
is there a drain valve and line on 04.5 fuell canster ? if so witch one.so tex
Old 02-25-2010, 07:11 AM
kry226's Avatar
Should be the yellow lever below the canister. There should also be a clear hose running down from the canister as well.
Old 02-25-2010, 12:13 PM
92'1stGen's Avatar
The clear house running from the fuel filter housing is kind of short, so if you take a section of old garden hose (5/8" I believe), it'll slip right over the clear hose and you can then extend it down to a drain bottle or pain. Makes it a lot easier and cleaner.
Old 02-25-2010, 06:22 PM
capnp72's Avatar
It's the yellow lever next to the canister. I just put an empty 2 liter soda bottle at the end of the clear tube to drain the canister.
Old 02-25-2010, 11:30 PM
sotex's Avatar
thank yal iwill use drain valve next time ichange filter.
klx650a2
01-10-2008 12:08 AM
Mechanos
03-08-2004 02:30 PM
6cylinders
03-06-2004 03:57 PM
TurboTed
02-11-2004 05:47 PM
wooff
05-01-2003 11:22 AM
Quick Reply: drain valve????
