View Full Version : DPF delete DIY
Tree DR
01-12-2009, 10:36 PM
Over on the cummins forum they give step by step instruction on how to do it. I'm going to try it this week and see what happens.
Tree DR
01-14-2009, 06:08 PM
Had to do it just pulled the plugs on my DPF and put in some resistors in the pyro plugs then I went to the dealer and got the AV flash they didn't say anything and no codes till later I got a P244a? I don't know what that is yet.
Chris Blevins
01-15-2009, 11:20 AM
I'm put a few of H S performance kits on the are pretty good kits but they will throw a few codes so you will need a programer to reset them every once awhile.
Tree DR
01-15-2009, 05:24 PM
I have a scan gauge so I can read a clear codes.
p244a is the pressure sensor in the DPF, there is not pressure since it's unpluged. Also just installed the straight pipe. Just a short trip since the install and no codes other than the egr unpluged P0405. I had the pipe made here and could get more made if there was enough interest.
Chris Blevins
01-15-2009, 08:02 PM
Its a day and night difference once you take out the filter but as far as I know their are no code free kits out I've been promised by to many companys, but if i brought a new truck thats the first thing I would do. Where did get the DPF pipe made at???
Tree DR
01-15-2009, 09:10 PM
I don't know about the day and night difference after the DPF removal. I got the exhaust pipe and took it to a local fab shop and they made the flange and welded it on for me. Yes I was under my truck on this cold day taking the DPF off. Since my truck is a CC it doesn't have the O2 sensors just a straight piece of pipe.
Chris Blevins
01-15-2009, 11:16 PM
Ya the CC trucks are not near as choked up as the pickups are man you should see them they even have a cat in the down pipe. How do you like the truck so far????
Tree DR
01-16-2009, 08:49 AM
I was hopeing for 4+ mpg improvement so I hope it was choked up that much. The truck is great, this is my first auto and I really like it except sometimes when pulling a trailer it doesn't stay in a higher gear and pull it wants to downshift and revup and go no where.
I'm going to put about 300mi on it tonight then I'll know better what it's doing as far as mpg and power.
Chris Blevins
01-19-2009, 09:44 PM
Any mpg difference??
Tree DR
01-20-2009, 05:29 PM
Maybe 2mpg is all I can say at this time. So why am I not seeing the 4+mpg so many people are claiming? I'm going to try and block off the egr tonight, I've had it unpluged.
If I don't clear the egr unplug code P0405 then the overhead will come on and tell me to take it to the dealer for service and the p244a code shows up. But as long as I clear P0405 before I start it no other codes show up and it runs fine either way.
Chris Blevins
01-20-2009, 07:28 PM
When I said it was a day and night difference the guys that I have done it for (very few) always had a tuner on their truck sorry I should have stated that. Have you thought of any kind of chip/programer yet?? I would wait til it had a few miles on it before I did if it was mine anyway. What kind of mpg are you getting???
Tree DR
01-20-2009, 08:16 PM
Was 12 now about 14 very little has been easy driveing. With 50 gal tank it's hard to get a complete tank of hwy or town. Most of my hwy has been at 70+. I did just plug the egr and first impression was the motor was much more responsive. With less than 4k miles on the truck I'm still hopeing the mpg will get better.
pln4472
07-20-2009, 01:02 PM
Tree DR, Did you ever put a tuner on your 5500. Did the mileage increase anymore after you unpluged the EGR. Did your exhust system have DPF and a muffler and you just removed the DPF.
Marlin
vBulletin® v3.6.7, Copyright ©2000-2010, Jelsoft Enterprises Ltd.
