*****down pipe problem*****
I just put on a 5" silverline exhaust system and im having a problem getting the down pipe to make a "full" connection i guess. The clamp goes on fine but its not holding it tight enough. The turboe is making a loud whistle and when i "stall" the truck, black smoke comes from the clamp. I have taken it off a couple of times and put it back on but i still get it to be right.....any thoughts?
are you talking about the v band clamp at the cast elbow or the style clamp mentioned above? THe one above you can get at any big rig dealer for about $7. just a tip, take some good reynolds foil wrap and wrap it around the joint a couple times before you install the clamp. wrap it tight then install the clamp and peel off any excess. I had a diesel tech show me that when I had straight stacks on my Peterbilt. Worked killer for a cheap gasket and never had problems.
mattmanj2001
Dec 11, 2010 07:33 AM
Jordan5687
Feb 14, 2007 05:00 PM
PADZZ
Feb 9, 2003 08:33 AM
