Door Panels!
My arm rest/grab handles on the '93 are broken, the handle and the panel where they screw down all toe-up! haven't had any luck at the junk yards, most of these AZ interiors are burnt up from this desert sun....... Any ideas??
I depends if you have power or non power. I have seen quite a few vendors advertising new non power panel's but I don't recall seing any new power panel's. I don't know the vendor names off the top of my head but if I think of them I will post it.
My panels were not tore up, but the arm rest was coming up. I took some construction adhesive and laid a couple beads under the arm rest. My interior is tan and what little of the adhesive is visible mostly matches and you have to look for it in order to see it.
It has been there 2 years and is still tight.... I was looking for a 4 week fix at the time.
If your panel is good except for where the arm rests mount in, then this may be a possibility.
ClawHammer
Jun 21, 2004 05:41 PM
