Door liner re. and re.
Old 12-27-2008, 10:04 PM
disco's Avatar
98 2nd gen. truck. I need to get at the speakers in the doors. How the heck do I get the liners off without doing any damage? Thanks!!
Old 12-27-2008, 10:26 PM
Fueling around's Avatar
In the tool or help rack at your auto parts store you will find a flat slotted bar to push in around the Christmas tree and save the door panel. I found the christmas tree is good for a second use. I bought a 100 bag of trees many years ago for about $5
Old 12-28-2008, 06:54 AM
CarlJensen's Avatar
Here are the clips. Got a small prybar? A slotted one works well to get the panels off after removing screws.
http://www.parts-express.com/pe/show...number=265-911
Old 12-30-2008, 02:43 PM
SIXSLUG's Avatar
Yeah, order the clips from that place in the above post.....the dealer wants $2.50 apiece and you need 12 per panel if they ruin during removal. Three screws, upper front corner and two in the pull cup then gently start to pull the panel away from the lower back corner and use the pry tool to avoid ruining the mounting flanges on the panel. Reinstall by putting the clips in the door panel and then reattaching the panel that way.
Kurt
Old 12-30-2008, 04:50 PM
Lil Dog's Avatar
New trees... I tried re-using them and had the panels rattle. I had to go get them anyway, so you may as well do it once!
CZSteve
03-08-2011 08:11 PM
iflych52
11-04-2006 09:40 PM
CSAGrey1
08-25-2006 04:11 PM
04ctd
02-18-2005 05:30 PM
Patrick Campbell
12-16-2004 01:53 PM
Quick Reply: Door liner re. and re.
