door bushings/swaybar
Old 05-17-2006, 05:43 PM
Buckshotram's Avatar
where can i get the replacement door bushings. I also need to get some swaybar bushings. Do they make them in ployurithene or is therir any advantage to them?
Old 05-17-2006, 07:30 PM
BigDodge's Avatar
Thumbs up
Summit racing has the sway bar bushing kits in poly aprox. Dont know about door bushings.
dave
Old 05-17-2006, 07:54 PM
dezlsmkr's Avatar
Goodluck finding door bushing i forget exactly how that went either you cant get the pins or the bushings one is not availible. The dealership told me you had to order whole new hinges at like 50$ or so for the bottom and 70$ or so for the top might be vise versa cant remember exactly.
Old 05-23-2006, 08:36 PM
meangreen96's Avatar
I bought a set of door bushings off of ebay from a guy named pussow. He put together a kit of hardened pins, bronze bushings, and instructions on how to go about modify your doors. The kit worked great, I put them on my '96. It was about $35-40, if I remember correctly - much cheaper than new hinges!!
-Craig
Old 05-24-2006, 06:56 AM
kd460's Avatar
I think I read on this site about using GM bushings and pins. Who ever talked about said they used the ones you can get at like Autozone. They are the "Help" brand of parts you always see on the rack.
He did have to drill to install the new ones, but it seemed to work well for him.
I'll see if I can locate the thread and post it here.
OK, here is the post I as thinking about:
https://www.dieseltruckresource.com/...ad.php?t=65258
KD
BearKiller
01-03-2011 11:50 AM
#2isgreen
10-06-2010 12:53 AM
samiam4
11-17-2007 06:23 PM
Mopar Kid
04-03-2006 06:59 AM
Quick Reply: door bushings/swaybar
