I don't have OEM tow hooks-- options??
Old 03-29-2006, 08:50 AM
HOHN's Avatar
My truck is an 02 SLT.
Can I just install tow hooks from the dealer? Or is it not that simple?
I have no decent tow points on the front end without them...
Old 03-29-2006, 09:05 AM
signature600's Avatar
I bought a kit from the dealer... a little spendy, but it worked great. ~$100 is what I paid
On your 02, all the holes should be there to bolt them up...it calls for 6 or 7 per hook, I have 4. I've pulled about 12-14 tons of truck and trailer from one hook, no problems! Only rated for 10K per hook, too
Chris
Old 03-29-2006, 09:26 AM
I PASS GAS's Avatar
Not the cheapest set up there, but I found some on Ebay. Click Here
Old 03-29-2006, 09:48 AM
Thats the kit I put on mine...guess I was a bit off on ratings
Chris
Old 03-29-2006, 06:48 PM
P Kennedy's Avatar
For about the same money you can mount a front reciever hitch kit which allows different types of hooks and puts the towing stress to more connection points and equalizes the pressure on the frame side to side. The factory tow hooks are prone to straightening because of the open loop design where as the reciever can accept a custom closed loop with proper shackle(clevis) for towing and lifting. If you need to be towed out and you use a single hook on 1 side of the frame the stress from the pull or jerk can spring your frame especially if loaded. The front receiver has all kinds of uses the tow hooks don't. PK
Old 03-29-2006, 06:53 PM
Dr. Evil's Avatar
Right you are PK....how about this Hohn?:
http://www.jcwhitney.com/autoparts/P...front+receiver
Likely cheaper than tow hooks.
Old 03-29-2006, 07:21 PM
GlennRMK's Avatar
Doesn't this hang low and kill clearence?
Any pictures installed?
Old 03-29-2006, 07:24 PM
P Kennedy's Avatar
The one that we mounted on my buddies 01 dually does go below the stock bumper but it fits tight to it and is even with the front bumper. PK
Old 03-29-2006, 08:14 PM
Dr. Evil's Avatar
"Ratsun" has a pic in his gallery...I think someone else does as well.
Old 03-30-2006, 03:39 AM
smoke_pedal's Avatar
Just hook it to your motor. If you pull on it, that's half the weight of the truck. Actually don't do that come to think of it.
Old 03-30-2006, 07:00 AM
CRSmith's Avatar
I put on a front receiver I ordered from Miley RV.com. It fit tightly to the underside. So much so that I had to cut the plastic license plate holder a little bit.
Old 03-30-2006, 07:36 AM
How about this HOHN, I'll buy a front reciever, and sell you my tow hooks??
I've been looking at one anyway
Chris
Old 03-30-2006, 02:34 PM
ratsun's Avatar
_______________
Sorry the pics a little dark but I had to cut the plastic air dam to slide the receiver hole on the hitch up into. Found a neat little fold-up step to slide in and keep out the crud.
Old 03-30-2006, 03:36 PM
willysrule's Avatar
front receiver is the only way to go...
Old 03-30-2006, 04:05 PM
HOHN's Avatar
I like the idea of the front receiver.
I might just have to buy a moose killer bumper to "properly" install it, hehe.
Quick Reply: I don't have OEM tow hooks-- options??
