Doesn't Blow hot
Doesn't Blow hot
I have a 97 12 valve and even after the coolant is up to temperature the heater doesn't blow hot or even very warm air. Does anyone have any ideas on this or experienced this problem before? Any help here would be much appriciated.
more then likely your heater core is shot. My buddy had the same problem with his 97. Last weekend we tore apart his dash and installed a new heater core, he says his heat cranks now. Replacing the heater core is kind of a PITA. The entire dash needs to be removed to get to it. If you are going to do the job yourself, i would buy a Haynes manual, it is useful, though a little vague, but it helps.
tlame
07-08-2014 09:29 AM
nvrenuf
01-01-2007 06:25 PM
Drivvven
04-20-2006 06:24 AM
