HOw does the pilot bearing install on an NV5600?
Old 04-03-2006, 02:05 PM
HOHN's Avatar
Is it just a simple press fit into the flywheel??
I doesn't sit in the crankshaft flange any, does it?
I'm trying to get a new Torque King pilot bearing installed with my new Clutch, but I'm having problems with clutch shops not being able to bore out the flywheel to install an O/S pilot bearing.
I'm having to piecemeal this job, as the guy who's installing the clutch can't resurface the flywheel, and the guy doing the flywheel can't bore it and press in the larger bearing.
I just want to confirm that I'm on the right track, here.
Old 04-03-2006, 02:36 PM
DTR Advertiser
Timinva's Avatar
I press it flush with a bushing driver. Tim
Old 04-05-2006, 05:57 PM
newriverSpecon's Avatar
The directions for the one from quad 4x4 (for the 4500) wanted a lip left on the crank side of the flywheel to keep the bearing from migrating fwd.
Randy
Old 04-05-2006, 08:10 PM
jaconst's Avatar
I just installed and tapped with rubber mallet until flush
Old 04-06-2006, 07:21 AM
HOHN's Avatar
Randy
The instructions they sent for my 5600 said this lip is optional. I guess the flywl sits closer to the crank on the 6-sp, and bottoms out on the crank before the bearing could fall out (forward)
ChuckT
13
12-19-2013 09:09 PM
pmtg
07-19-2007 08:47 PM
Rattletrap1
07-11-2007 12:12 PM
wadecool
01-12-2007 11:39 AM
dewclaw
10-04-2002 09:50 PM
Quick Reply: HOw does the pilot bearing install on an NV5600?
