does it have to be
Old 09-28-2011, 06:28 PM
Sawyer1's Avatar
Angry does it have to be
I went and bought a guage and 1/8 tubing to install a fuel press guage in my truck but can't for the life of me find a 1/8 x1/8 needle valve. Can I use a 1/8 pipe x1/4 tube needle valve instead or would that cause problems?
Old 09-28-2011, 08:35 PM
TheWaterman1000's Avatar
It should work. Just make sure It will not leak. Have you thought of using a snubber. I bought mine at tork tek and works great. I thought about the valve, adapter,etc.. but the cost of the snubber is worth it. Say hi to Rob and tell him hope his hand is getting better. You would need to install an isolator. You don't want diesel going into the truck if you get a leak.
Old 09-29-2011, 10:03 AM
infidel's Avatar
The correct needle valve is often used for refrigerator ice makers and available in an installation kit from most places that sell appliances.
Old 09-29-2011, 11:02 AM
Dr. Evil's Avatar
Not sure where you are but Edmonton (and Calgary) Valve and Fitting has 1/8" Swagelok needle valves.
Old 09-29-2011, 12:50 PM
Sawyer1's Avatar
I live nears Brooks and these common things are not so easy to come by out here in the boonies.
Old 09-29-2011, 05:56 PM
Dr. Evil's Avatar
Not true at all. When I worked at the power plant down there we got all our fittings from Brooks Valve and Fitting. Get a brass needle valve. Im not at work so I dont have my catalogue in front of me, but I will get you a part number next week if you want it. The valve wont be real cheap but its a top quality (best in the business) part.
Old 09-29-2011, 11:25 PM
Sawyer1's Avatar
thanks for the info,I will check with them tomorrow. Didn't even know this business was in Brooks,I don't go to town much.
tex23455
12-12-2007 10:31 PM
drewallen42
04-14-2007 01:07 PM
VikingDiesel
17
12-30-2006 09:19 AM
routerguy99
17
08-11-2003 12:21 PM
Quick Reply: does it have to be
