what does this do
Old Mar 5, 2007 | 07:34 PM
DODGE 92's Avatar
what does this do
well i put my transfer case back on and i dropped it and i broke that sensor thats close to fuel tank what does it do is it important or can i live without it
there is a small gear in there the only thing thats broken is the tube itself no broken gears or bent little shafts
Old Mar 5, 2007 | 08:08 PM
BC847's Avatar
1st Generation Admin
That is the speedometer hook-up.
Old Mar 5, 2007 | 08:27 PM
dieselJon's Avatar
my speedometer doesnt work either. Um, Oskifer? It done wont work. Didnt know I was doing 75 in a 55! Now can you foller an' done tell me when I hit 60 please. A friend told me that part (the big black box) cost him around $60 and 15 minutes of time.
dieseljon
Old Mar 5, 2007 | 08:48 PM
BC847's Avatar
If you need to alter the speedometer's calibration for over-sized tires, now's the time to do it (See those little gears).
Old Mar 6, 2007 | 06:34 AM
Chrisreyn's Avatar
D92, the Variable Speed Sensor(VSS, the peice that screws onto the Speedo sender and that the electrical connector plugs to) can be got at NAPA for around $40. If your set up requires teh 90 degree gear reducer, that is a dealer only part that will run between $100 and $150 dependign on your application. If you broke the male threaded peice that is actually in the transfer case, that is the "pinion gear retainer" and I happen to have a spare one I'll send ya for nuttin if it will work for your app.
Old Mar 6, 2007 | 10:11 AM
DODGE 92's Avatar
speedo
ok so its the speedo thats good to have thanks chris ill check whats broke and get back to you guys
another question the semsor that is on the vibration damper is that for rpm what does that do for my truck i dont have a rpm guage is that where i hook it up if i deside to put one in
Old Mar 6, 2007 | 03:27 PM
The crank sensor tells the computer that the engine's running so it will charge the battery and run the A/C.
Old Mar 6, 2007 | 05:04 PM
DODGE 92's Avatar
crank sensor
so a good way to no if its properly set is what
my voltage gage wont work cause alternator is not charging
or ???
just looking for a way to troubleshoot
Old Mar 6, 2007 | 05:11 PM
The gap should be 0.050".
Check the wiring for breaks in the insulation.
Old Mar 6, 2007 | 07:36 PM
DODGE 92's Avatar
gap
i gapped it just did not try it yet havent finished putting it back together im a bit lazzy but if it doesnt work what are the signs
no voltage on guage or something like that???
Old Mar 7, 2007 | 05:50 PM
Yep. No charging, and the A/C and cruise crap out too.
Old Mar 7, 2007 | 07:49 PM
DODGE 92's Avatar
sensor
ok ill check that out i dont have ac and cruise so only way to no is no charging
skahla
Nov 20, 2009 08:13 AM
tex23455
Dec 12, 2007 10:31 PM
drewallen42
Apr 14, 2007 01:07 PM
VikingDiesel
17
Dec 30, 2006 09:19 AM
