Does 4.11 feel stronger than REVO to you?
Old 08-18-2008, 07:21 PM
LFD2037's Avatar
It seems like 4.11 SW9 feels stronger than REVO SW9 to me. With 4.11 my truck will roast the tires HARD, even in 2nd, but w/REVO it will hardly break them loose & nothing in 2nd. Does it feel weaker because it provides power @ a different RPM or am I just crazy?
Old 08-18-2008, 09:37 PM
ThatGuy34's Avatar
what tq management level are you using on the revo
Old 08-19-2008, 10:23 AM
LFD2037's Avatar
For my comparison it was Wild TM on both.
Old 08-19-2008, 11:37 AM
jlibert's Avatar
Not on my truck. 4.11 felt super weak on top, revo was pretty nice.
Old 08-20-2008, 12:50 AM
ddestruel's Avatar
Location: Used to be missoula, montana: Now in Sonoma County California
towing i lost 4 psi top end boost with revo when towing.
Towing same 13k lbs load up same donner summit I80 grade.
4.11 aftermarket turbo stock injector program mild torque management level 9 less smoke minimal smoke. 38 psi total WOT boost. more controlable smoke. much better milage towing and not. overall better towing program for my 03 tripple nickle.
Revo Mild TQ management fueling level 9 no changes to timing. added fuel pressure made 36 psi and without fuel pressure 34 psi
more smoke all around and 2-3 mpg loss across the board stronger mid range weaker on the top
all said and done REVO will pull the grade about 6 mph less at WOT than 4.11 for me but thats on an 03.
Old 08-20-2008, 07:56 AM
tcr
tcr's Avatar
I've found the Revo pulls harder on top end and I didn't notice this until I upgraded the CP3. Did you try the Revo on #7 RP on #3, my truck loves this setting for some reason.
Old 08-20-2008, 09:48 AM
LFD2037's Avatar
I'll try SW 7 & see. Thanks for yall's input!
trefling
11-30-2007 11:23 AM
KVD
07-03-2007 06:38 PM
04ctd
02-08-2007 10:53 PM
KVD
12-15-2006 05:39 PM
kelownadiesel
11-15-2006 11:56 PM
Quick Reply: Does 4.11 feel stronger than REVO to you?
