Does a 2004.5 48RE torque lock up?
Old 01-09-2008, 07:46 PM
sallyman1's Avatar
Does a 48RE torque lock up in overdrive or only when tow haul is pressed (3rd)? how can u tell if your torque locks up? rpms drop? do u want it to lock up when empty or when towing?
Old 01-09-2008, 08:00 PM
Rpainter's Avatar
it does lock up and if I remember right it should lockup in od at 54 mph When it is locked you get less heat and a little better fuel mileage
Old 01-09-2008, 08:10 PM
MMMmmmm.... Grits!!
ratlratl's Avatar
Thumbs up
In stock configuration, as best I remember, the tranny doesn't go into lock up in first. It does go into LU part-time in 2nd and 3rd. Unlocking before shifts. It immediately goes into lock up once into OD or 4th. IIRC putting it OD off or 3rd at speeds over 45 it will be in LU. Let off the accellerator pedal and once it drops to a certain RPM it comes out of LU. Thus the run away problem going downhill. LU is best described as like a manual truck. It's a direct drive of the motor to the trans. The RPM's will drop slightly. Third feels like it shifts twice. It is better to be in LU as more pulling power is being sent from the motor to the drivetrain. I'm sure others will chime in and fill in the details I've missed here.
Chris
Old 01-09-2008, 09:18 PM
sallyman1's Avatar
thanks for the info
Old 01-09-2008, 09:50 PM
omaharam's Avatar
Chris
Only one problem with the above info. The TC will only lock in 2nd if the gear selector is in 2nd. If you just leave it in "D", it only locks in 3rd and 4th.
Capp35
02-22-2009 09:17 AM
Bullit
26
02-02-2008 11:47 PM
5.9Excursion
23
01-04-2008 10:39 PM
Nuttymopar
09-02-2004 07:39 AM
damon_achey
06-07-2004 03:33 PM
Quick Reply: Does a 2004.5 48RE torque lock up?
