Does an 03 Need a Boost fooler w/Smarty?
Old 09-14-2009, 06:16 PM
BigBully's Avatar
I have heard they dont and I had heard they do?
Old 09-14-2009, 07:10 PM
ModManiac's Avatar
nope, not to my undestanding.
Old 09-14-2009, 07:48 PM
JP-4.5's Avatar
Just plenty of fuel needed...
If you plan on pushing it .
Old 09-14-2009, 07:50 PM
JJPage's Avatar
Smarty will boost fool to about 44#s. If you are going to exceed that you will need additional fooling to keep from throwing codes. If you have the stock 03 turbo, 35#s is about as much boost as it will handle.
Old 09-14-2009, 11:09 PM
BigBully's Avatar
Ok Thank you Guys, I push 50+ lbs but havnt seen a boost code yet.
Old 09-15-2009, 03:08 PM
JP-4.5's Avatar
I did not think the ECM would give the codes until my year 2004.5, when the wastegate went electronic.
Old 09-15-2009, 08:44 PM
JJPage's Avatar
Well you could be right, I have never seen a boost code and I have surpassed 60+ lbs. I also run EZ and TST which both do additional fooling.
BBRam on Cummins Forum told me he was throwing codes on his 03 @ 53 lbs. He is a reliable source imo.
I am not sure if a cel would accompany a boost code or not, maybe they clear themselves after so many key cycles, but I have not witnessed one on my truck.
Killdmycobra
11-12-2010 05:15 PM
sCreamin400
25
05-10-2010 10:14 PM
Big Horn
13
01-26-2008 10:18 PM
nrussell
01-13-2008 07:00 PM
Rollin' Smoke
23
06-26-2007 09:04 PM
Quick Reply: Does an 03 Need a Boost fooler w/Smarty?
