Dodgezilla
Old 05-03-2004, 06:23 PM
More Power's Avatar
Dodgezilla
Anyone running a dodgezilla around 400hp. Do you like it or wish you would have went with a hx 40?
Old 05-03-2004, 06:38 PM
Bob Wagner's Avatar
citydiesel now offers a nice hx 40 too . I am very happy with the dodgezilla
Old 05-03-2004, 07:14 PM
More Power's Avatar
what size edms are you running and with your comp on 5x5 do you reach 1500 degrees quickly?
Old 05-03-2004, 10:03 PM
Bob Wagner's Avatar
I used to run Mach 3's which were rated 140HP , but since then I've switched to Mach 2.4's which are rated 110HP do ot the summer towing factor.
I tow a 30' 10k+ 5er during the summer months. The Mach 3's may have been too much injector to towing a heavy load so I am playing it safe.
I must say the 2.4's were not much of a downsizing, great power and torque.
I have yet to tap the pump wire (over 2years )
I choose to look for larger injectors for added fuel
Don~ puts out a great products
Old 05-04-2004, 01:24 AM
renegade681's Avatar
I like the Dodgezilla with the 14 WG housing. But it sounds like I shoulda went to a 40 instead. Overall if I keep the box set to 1X5 I'm ok for the most part, but I'll be adding water to be on the safe side I hope . By the way I dynoed out at 472 and 1001 with 36lbs of boost on a dynojet at 5029ft. Box set on 5X5 I can hit 1600 REAL quick.
Old 05-04-2004, 07:15 AM
Jim Fulmer's Avatar
As long as you can control the boost hit when you light the water off you should be fine, at your temps you definately need water.
Jim
Old 05-04-2004, 04:52 PM
Hey Jim Fulmer, I was thinking about that snow performance stage 2 I think with the varible controller then I could adjust the water to come on at a certian boost at 50% then 100% at WOT right? For the most part I want it for hauling up over the passes in the summer.
00turbo
07-12-2004 08:54 PM
JaMan
03-07-2004 05:24 PM
DeereDiesel
33
02-04-2004 11:16 AM
deltafarmer
11-23-2003 05:21 PM
onesloryd
13
11-11-2003 02:48 PM
Quick Reply: Dodgezilla
