Dodge Cummins exhaust brake
Old 06-24-2007, 02:57 PM
Shoe65's Avatar
Had problems with mine working when it wanted to. I just needed to adjust the microswitch on the pump linkage.
Doesn't skip a beat now.
Good luck!
Old 06-24-2007, 03:02 PM
DTR's Toad Wrangler
Clayten's Avatar
What make of brake is it?
Old 06-24-2007, 03:29 PM
Shoe65's Avatar
I am just assuming Polarihog is running a Pacbrake.
We both need to update our sig. I am running a old style vaccuum Pacbrake.
Old 06-24-2007, 06:08 PM
Danavilla's Avatar
A fairly common problem with vacuum actuated e-brakes is the "spool valve" that can get gummed up over time. Simple disassembly, cleaning and lubing are all that's required much of the time.
What brand and model brake is it?
Did you try that company's web site for the schematic of the valve?
Dan
Old 06-24-2007, 09:53 PM
DTR's Toad Wrangler
Clayten's Avatar
Here is two links that should help you.
http://www.piersdiesel.com/TechSolenoid.htm
http://pacbrake.com/PDF/L2014.PDF
Old 06-25-2007, 09:55 AM
Harold-Pacbrake's Avatar
Regardless for the brand of exhaust brake Pac or BD the vacuum solenoid has two screws holding the coil on, remove the coil, you will find a white oval spacer, inside the body you will find a control valve that looks like a cam, remove the C/V and clean it in mineral spirits, or your wife’s nail polish remover, clean the inside of the solenoid body and reassemble. The most common problem with vac operated brakes is the solenoid needs cleaning. If you need further help drop me a line
Old 06-27-2007, 03:46 PM
GAmes's Avatar
I have the same unit. Jacobs is owned and sold by Cummins. Is there a Cummins/Onan dealer near you? They might be able to provide a schematic. My truck is parked in VA right now and I am in TX but will be back there this weekend. I think all my installation paperwork is in my toolbox. If you haven't tracked down the problem by Sunday PM me. In the meantime confirm that the micro-switch that is mounted on the engine gear case and is open/closed by the throttle linkage is working and in adjustment. After 500k miles, that is the only part that has failed on mine.
Old 06-28-2007, 11:21 AM
I think Jakebrake.com has the manual and drawsing on their site
1stgenatheart
10-19-2009 06:33 AM
howe719
18
10-18-2007 02:35 AM
ProjectM880
12-01-2004 06:40 PM
Maccandy
08-20-2004 11:02 PM
jahluvdiesel
12-26-2002 01:15 AM
Quick Reply: Dodge Cummins exhaust brake
