what do you think?
Old 08-07-2008, 08:15 AM
kyncl's Avatar
what do you think?
I found these injectors on ebay. They sound really cheap. Are these good injectors or should I stay away from them. They are Jammer injector nozzles. Stage 3. Thanks.
http://cgi.ebay.com/ebaymotors/DODGE...mZ380052565452
Old 08-07-2008, 09:48 AM
AggieJustin's Avatar
Just to make sure you are aware, those are only the nozzles. They are not full injectors. Once you get them, you'll need to have them mounted on a set of injector bodies.
Stage 3 nozzles direct from Edge are ~$245. The full Stage 3 injectors are ~$596.
Old 08-07-2008, 09:49 AM
kyncl's Avatar
Never mind.. I did a search. I think I will buy some better ones.
Old 08-07-2008, 09:50 AM
kyncl's Avatar
thanks for the info
Old 08-07-2008, 10:13 AM
Just to follow up, the Jammers are a good "budget" injector. But there are better ones to be had based on all the feedback I've ever heard.
If you do decide to get nozzles instead of full injectors, make sure you have someone spend the time when installing the nozzles on the bodes to get them calibrated to all pop-off at the same pressure. This goes a long way into making them a much nicer injector to run.
cyawallac
11-01-2011 11:37 PM
rossco
08-23-2007 06:17 PM
bigfoot
05-11-2004 04:54 PM
westcoaster
01-26-2004 11:20 AM
Quick Reply: what do you think?
