do you need a gasket scraper for CFM+ install?
Well it depends. When I did mine, I did have to use one in just a couple of areas where the old gasket stuck. Most of it though just lifted right off. You might get lucky and have it all come off no problems, you might not.
Scotch brite pads work the best. Put a towel in the intake before you start.
I also used a shop vac to clean everything again b4 reinstall. The heater grid can be cleaned on the bench, a scotch brite type of pad won't gouge anything.
Eric@TVP did a dyno test on this and showed very modest gains (I think 6 hp) with the grid delete.
sawboywv1
Jan 25, 2008 06:58 AM
ddestruel
Dec 25, 2007 06:28 PM
joefarmer
Jun 7, 2006 02:12 PM
