How do you get the power window
Old 07-25-2005, 10:03 PM
Dojman's Avatar
switch panel loose from the door without tearing something up? '01 model My drivers side switch for passengers window will not send the window down? Up is fine. Did I not see, some time ago, an easy fix for this?
Old 07-25-2005, 11:00 PM
Dojman's Avatar
I found an old post about it. Say the panel just "pops" out?
Old 07-26-2005, 09:29 AM
mamm7215's Avatar
Basically you just get a screwdriver and GENTLY lift up under the edge and then grab it and work it up. It's only held in by 2 retainer clips on each end. You may need to replace 1 after as they tend to break but they're cheap, dealers have 'em.
C Schomer
09-21-2014 03:19 PM
Rednecktastic
08-29-2010 11:26 PM
raven392003
10-29-2007 11:39 AM
Quick Reply: How do you get the power window
