what do toy guys think
Old 06-25-2009, 05:39 PM
chali84's Avatar
I dont know if you guys have heard of twisted diesel out hear in va but they are mainly a ford diesel performance company but the owner is a good friend of mine and we have been talking about the build for my truck. what do you guys think
it will be mainly a sled puller and weeknd driver for kicks but
we decided to go with a custom 71 mm gt40 for the 2.8 class and ddp 250 injectors
assuming i can provide the fuel with the Glacier diesel fuel boss kit and build the tranny with a little higher stall for spooling what do you guys think the truck would be capable of power wise. my dragcomp will also be stacked with a smarty
Old 06-26-2009, 12:24 AM
Tate's Avatar
What are you going to do for an IP? Stock VP won't be very competitive in the 2.8 class.
Old 06-27-2009, 12:32 PM
cumminsdriver635's Avatar
I wouldnt go any bigger than a 66mm charger if you are just running a VP44.
Eric
Old 06-29-2009, 04:08 PM
chali84's Avatar
some sort of hot rodded pump not to sure which one yet
why shouldnt i go over a 66 mm
i know it will be laggy as all get out but twins cant run 2.8
Old 06-29-2009, 04:09 PM
chali84's Avatar
havent heard a lot of good things about dragon pump might go with schied
Old 06-29-2009, 05:35 PM
kawi600's Avatar
^2 for the Scheid pump.
Old 06-29-2009, 05:43 PM
I dont think you will have enough fuel to need anything bigger than a 66mm charger, and it will spool better.
Eric
Old 06-30-2009, 04:23 PM
chali84's Avatar
Eric
if you can run an s480 in a set of twins like some people do you can run and s480 as a single. yes it will be laggy but you cant run twins in a 2.8 class plus twins are only aloud in the big pulling class so its all out or nothing
My 71mm gt 40 yes is big and will be laggy but it is more purpose built for sledpulling and occasianal weekend running. I know the vp44 trucks cant flow as much fuel as the 12 valve or common but i think they can make that turbocome to life as a single
04ctd
09-10-2006 02:58 AM
bentwings
07-09-2004 02:23 PM
Cumminsdude
04-26-2003 04:19 PM
powerwagon440
04-19-2003 07:19 AM
doodah
03-17-2003 12:27 PM
Quick Reply: what do toy guys think
