What to do next
Old 12-27-2007, 11:13 PM
deereguy07's Avatar
What to do next
I'm wantin yalls opinion on what to do next. I know i need a turbo and have been lookin at them but can't make up my mind on which one I want. I'm wantin to a 5k gsk in it. (this is a pullin/fun truck) I know I probly need to go ahead an put studs and a gasket on it. I'm not that impressed with the 370's I've got and I think my dv's are jus 191's so I'm kinda thinkin of gettin some different injectors and dv's. Can't make up my mind on them either. lol What do yall think I should go about doin next? Any help would be appreciated. Thanks
Old 12-28-2007, 12:05 AM
displacedtexan's Avatar
I'd do turbo, then new sticks.
You will need some bottom end work to turn over 4k...
Old 12-28-2007, 08:07 AM
deereguy07's Avatar
What r u meanin by bottom end work? A friend of mine that I pull with is turnin 5k on a stock bottom end and it does fine. Just wonderin
Old 12-28-2007, 09:56 AM
10seconddodge's Avatar
When i put the 5k spring in it lasted about 100 miles on the stock bottem end before i had to get some upgrades.. New crank and berrings i also went and did pistons and cam when it was tore down
Old 12-29-2007, 08:33 AM
deereguy07's Avatar
Well I for sure don't want to ruin a crank or anything else. I will have to look at my friend's and see. I don't know if he put new bearings in before the 5k or not. May jus have to go with a 4k this season and disassemble it next winter and do bearings and cam and such. Do yall know of anyone runnin a S300 or S400 Turbo?
Old 12-29-2007, 12:30 PM
97' CTD's Avatar
Most all aftermarket chargers are based off S3's. You dont need anything done to the bottm end to spin over 4000RPM you are just running a risk but, we all like to take risks .
Brandon
Old 12-29-2007, 10:48 PM
deereguy07's Avatar
I need to get the turbo for sure. Yea we all take risks I agree. lol I can't afford a risk like that if it don't take it. I may jus try to run 4k this year or untill I can afford to disassemble the motor and clean everythin and put some new parts in. Do ya'll think with my current set up and 4k springs and a 5 or 6spd manual and a S300 could be a stout truck?
Old 12-29-2007, 11:28 PM
Get the right 300 and it would be prety stout... You building it to pull?
Old 12-30-2007, 06:02 AM
97' CTD's Avatar
Put 5K's in.
Brandon
Old 12-30-2007, 09:27 AM
deereguy07's Avatar
Yes I am buildin it to pull with. I pulled with it like it is this past year. I need rpms bad. And more fuel. lol Which 300 are you talkin bout bein the right one?
I want to 5k but I will jus have to see.
I'm tryin to convert the truck to a manual now jus waitin on parts.
CurtisvilleCummins
03-10-2003 02:24 PM
02-20-2003 08:17 PM
Fillerupsonny
11-21-2002 08:51 PM
Dusty 96
10-13-2002 06:54 AM
Quick Reply: What to do next
