Do I need a towing turbo?
Old 01-09-2008, 08:30 PM
popeyesides's Avatar
Howdy,I tow a 40' toy hauler that weights 15,000lbs. all the time,I hit 38-40 psi regulary and my egt's never go over 900degrees(post turbo)since I put a zilla boost fooler on last year which dropped my egt's by 200-300 degrees..I wouldn't mind a little more power for headwinds.Is my stock turbo fine with this or what should I change it to?I really don't want any tuners that may void my warranty.I only have 20,000 mi.on the truck and use it to tow only.Thanks for any info.
Old 01-09-2008, 08:35 PM
flywheelman's Avatar
I realize this is not a reply to your post but heres my problem. I want to make a new post but can't seem to find the way to make one, will someone please explain it to me?
Thanks,
Flywheelman
Old 01-09-2008, 08:38 PM
DTR 1st Sergeant
soulezoo's Avatar
Just putting on a different turbo will void your warranty too. If all you are hitting (and that pyro really should be pre and not post turbo) is 900* (say maybe 200 more for pre turbo) then it is ok as you are especially if you don't want to change anything.
Old 01-09-2008, 08:50 PM
Thanks Soulezoo,is there a twin turbo set up that would work great for towing since now I know a turbo will void warranty,I would like some more power when we go fromm Az. to Idaho.
Flywheel,To post,pick what forum then look at the top left and you will see "Post new topic"Thats it.
Old 01-09-2008, 10:12 PM
Summit's Avatar
Need to call Nathan and stop by next time you come to Idaho, he's in Boise.
he will build what suits your needs not just a generic set. im sure others will chime in.
http://www.maximizedperformanceinc.com/
Old 01-11-2008, 01:42 PM
What would be better for my towing needs,Smarty or Smarty Jr?
Old 01-11-2008, 07:34 PM
BRayls's Avatar
how about pocket book. take the smarty.
Old 01-11-2008, 08:14 PM
eldgenb's Avatar
I would go smarty as it will not void you warranty unless you leave it in when at the dealer and if you are looking for a little extra then the smarty Jr. would be your best bet. They are on ebay for a great price.
Old 01-11-2008, 08:38 PM
I'm not concerned about my pocketbook, I just want the best bang for my buck. Does the smarty have a towing level like the smarty jr.? Thanks for all the info, thats what great about this site.
Old 01-12-2008, 12:50 PM
jgiachino's Avatar
Smarty
Smarty doesn't specifically have a towing level, but the lower levels are very close to the smarty jr. ...e.g. 30/40, 60/70, 90/100hp....it's the same basic software....latest smarty has stupid low egt's, very smooth and get's great reviews for towing, excellent power....with a stock clutch, you're not going to want to go any higher than 60/70hp (level 3 on standard smarty)....if you're not worried about $'s, get the smarty sr. as it's more flexable and can grow with your truck....
I''m in North Phoenix (Happy Valley and 51st)...if you want to give the smarty a test run, you're welcome to.....it's a no risk proposition...you'll be very happy with it. email me at jgiachino@hypercom.com if you want to give her a try.
Old 01-12-2008, 01:28 PM
DTR 1st Sergeant
soulezoo's Avatar
As mentioned above, Nathan at MPI is a great resource. Nice thing about him is he will custom tailor whatever you want, not necessarily just of the shelf. That said, there are a number of "off the shelf" twins that are wonderful for towing and work stupid well. I have Piers towing twins--they are "old school" but I couldn't be happier with their performance. Other options are BD and ATS and some others. Do some research before you lay down that kind of $$ but you really can't go wrong with twins and towing if you can afford it.
Old 01-12-2008, 01:55 PM
Tuf-4x4's Avatar
Doese the Smarty Sr. come with a boost fooler or would it be a good idea to leave the Zilla boost fooler on with the Smarty?
Old 01-12-2008, 03:16 PM
jgiachino's Avatar
THe correct software downloads "aftermarket turbo" for smarty will boost fool...i hit low 40's w/o any other boost fooling device.
edonald849
02-22-2009 04:44 PM
Tuf-4x4
17
01-30-2008 08:44 PM
popeyesides
01-11-2008 01:55 PM
cincydiesel
06-23-2007 08:39 PM
Trusty Steed
02-24-2004 07:11 AM
Quick Reply: Do I need a towing turbo?
