What do I need to do???
Old Sep 16, 2006 | 08:05 PM
99blackrig's Avatar
What do I need to do to keep my egts down?
I want to be able to run the edge juice on 5x5 all the time but I just peg the pyro too quick. I've heard that people with my same set up are not running into egt problems like me, what gives. On level 5x5 if I floor it off the line the cars behind me will dissapear but the smoke clears up by second gear. But by then I have to let off of the pedal to control my egt's.
I have a stock Hx35 with a banks 14 cm big head wastegated housing, 4 inch exaust and the stock airbox with a k/n filter.
The only setting I can leave it in without hitting my 1250 degree setting is 2. On 3 I can leave it pegged for the most part but have to let up alittle.
Old Sep 16, 2006 | 08:48 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Bigger CowBell (More Turbo)
Old Sep 16, 2006 | 09:01 PM
99blackrig's Avatar
Mabye I will call HTT and see if they can upgrade mine.
Old Sep 16, 2006 | 09:03 PM
Marine's Avatar
Veteran: Marine Corp
I have the same prob with my set up (in sig) I could go with a bigger single, but because of my 91% TC, I would have a lot of lag. I am going to twins!
Old Sep 16, 2006 | 09:05 PM
Diesel Dummy's Avatar
i dont have a problem with it, is your cat and muffler gone?
Old Sep 16, 2006 | 09:10 PM
99blackrig's Avatar
4 inch straight piped, no silencer.
Old Sep 16, 2006 | 09:21 PM
Shovelhead's Avatar
He also has an Aftermarket Trans/Torque Converter & larger than stock injectors.
Old Sep 16, 2006 | 10:06 PM
bigger injectors= higher egts, especially with the juice. You need to move more air, bigger turbo will surely help.
Old Sep 16, 2006 | 10:23 PM
99blackrig's Avatar
Do you think changing my intake from the stock box with a k/n to an afe would help??
Old Sep 16, 2006 | 10:35 PM
well if you have bigger injectors you should have atleast got a high flow air intake to get more air to go with more fuel. It would be a good idea to upgrade. If you read the diesel power mag they did a whole section on air intake systems, they found out there is really no gain to doit on its own, but in your case it would be a real gain. (my opinion only )
Old Sep 17, 2006 | 06:18 AM
getblown5.9's Avatar
get the AFE but with all that fuel on the hx35, you are not gonna see much drop.
best turbos for your set up would be HTB2 62/12, or a phat shaft 62 from industrial injection. they spool well, cool well, and will make good power with the juice and 1.6's
Old Sep 17, 2006 | 07:48 AM
99blackrig's Avatar
Would a used htb2 for around $900 be a good deal. It is only about months old.
Old Sep 17, 2006 | 11:42 AM
Ph4tty's Avatar
Sounds like a good deal on that HTB2
Old Sep 17, 2006 | 04:45 PM
99blackrig's Avatar
I just went out and turned off the warnings put it on 5x5 and the most I hit 1450egt. After a quarter mile run it smelled a little hot, kind of like burning plastic. But that went away and everything runs fine. I wonder how many times I can do that before something melts .
I ordered a Afe stage one so hopefully that will nock off a few egts....
Old Sep 17, 2006 | 06:16 PM
12valve's Avatar
wow!!! it aint that bad!!
i hit 1600 way before the 1/4 mile!!!
and if it smelled like plastic, it aint you pistons
rjm022
Aug 20, 2006 07:17 PM
JARHEAD
Feb 25, 2006 11:52 PM
v8440
Sep 7, 2005 08:39 PM
PapaPerk
Nov 29, 2004 09:13 PM
