View Full Version : Do i have a problem...
thatguy
11-01-2002, 06:07 AM
I have an EZ Oil Change valve (from geno's garage) and changed my oil last nite (truck was warmed up, let oil drain until it only dripped out), and my driveway is on a slight slope (front lower then rear)... I put 11 qts (10 + 1 in the filter) back in it.. <br><br>When I check the oil on the dip stick it reads about 1/2 qt over the 'safe' mark... I am fulling pushing the dipstick in when i check it..<br><br>Do I need to drain the oil down to get it at or below the 'safe' mark?<br><br>Would the EZ valve keep ~1/2 qt from draining out? it does stick up above the bottom of the oil pan.<br><br>thanks..
Smokee
11-01-2002, 06:23 AM
I certainly wouldn't worry about a slight overfill like that one. Almost always on my truck, when I check the next day, it is 1/2 qt over...draindown, I think.<br>george
Commatoze
11-01-2002, 06:25 AM
Yep, what Smokey said. That valve is nice isn't it?<br><br>-Tom-
thatguy
11-01-2002, 08:42 AM
thanks for the advise on the overfill.. I didnt think 1/2 qt would be that much, but just wasnt sure...<br><br>The EZ valve is so, so NICE! No mess, no oily hands..<br><br>Now i want an EZ valve for my gf's 2002 Honda CRV.. Anyone know what size drain valve it has??<br><br>thanks for the advise..<br><br>b
cr1998
11-01-2002, 11:08 AM
It never ends, does it? Adds EZ Valve to wants needs list. Hopes wife doesn't find list. ;D
CR
Pretty sure that little bit of overfill would never hurt anything.<br><br>Probably not even enough to make it foam a bit.
chuck3
11-01-2002, 08:56 PM
Very few of these Dipsticks read correctly, not you Hoss the oil dipsticks. ;D
vBulletin® v3.6.7, Copyright ©2000-2010, Jelsoft Enterprises Ltd.
