How do I get my 35 hp back?
Yes, I would like to get my 35 hp back but how?
My California model 97 5 spd is only rated at 180 hp where as a Federal 5spd model is at 215 hp. I know Dodge added an EGR in California model but if I removed that, would it give me back my 35 hp? It doesn't have an ECU to control the engine's fuel/timing map so I know it's not there.
I can always add a fuel plate but doesn't that mean I'm still 35 hp less then non-California 97-98 CTD? What caused the lost of 35 hp?
Su
Su
if you got a 180 pump and dv's on that 5 speed and want the 215 you will probably have to get a 215 pump to regain your hp. I thought they only put the 180 on automatics?
Here's the information I got from turbodieselregister.com
* 215 HP and 440 ft-lbs for manual transmission.
* 180 HP and 420 ft-lbs. for automatic transmission.
* California engines continue with EGR but are offered with 180 HP and 420 ft-lbs of torque in both automatic and manual transmission applications.
I guess I have the 180 pump.
Su
Su
here is a link with info,if you look up your CPL # and then scroll to the bottom of the page it has a chart of the engines with 215 pumps, you have a 180 according to this...http://dodgeram.org/tech/dsl/Facts/Cpl.htm
02guy
04-23-2008 07:43 PM
pwrtripls1
21
04-10-2006 09:01 AM
JoshPeters
04-03-2005 08:13 AM
Rumbles
05-24-2004 02:26 PM
