DIY CP3 upgrade is it worth it?
Old 10-23-2009, 05:34 AM
1985cucv's Avatar
i was wondering for those of you that have upgraded your cp3 by yourself if it was worth it? what are the down falls and what are the benefits to this mod? obviously higher rail pressure but is the mod worth it? also how did it affect your fuel mileage thanks guys
Old 10-23-2009, 11:42 AM
DTR 1st Sergeant
soulezoo's Avatar
The mod was worth it to me. To see the difference you have to be on the cusp anyway. The only downfall is if you are not really careful you can bugger your FCA easy and buy a new one. It will not affect fuel mileage one bit. Also it does not per se give you higher rail pressure. That is commanded by the ecm. The mod only lets you be better able to maintain that commanded rail pressure.
Old 10-23-2009, 08:10 PM
1985cucv's Avatar
10 4 i might get a new fca and just mod it that way. what kind of sandpaper did you use i have some 400 grit is that enough? also what size drill bits did you use if you remember? for the plug and holes in the plate.
1985cucv
06-01-2010 09:36 PM
OldSmokey
191
02-25-2008 03:26 PM
BigJohnston
01-30-2008 12:50 AM
subspd
08-27-2006 02:17 PM
Quick Reply: DIY CP3 upgrade is it worth it?
