disable auto door locks ?
Old 06-08-2009, 06:31 PM
mikmaze's Avatar
saw a thread in the 2nd gen section a feature that lets you shut off the auto door locks...... I absolutely hate the fact that the dang truck locks the doors after a set mph/ distance whatever....... you know the fealing, get out of the truck, walk around the other side and the dang door is locked...... how many times has this happened to you ? and isn't there a way to stop it ? someone must know the trick to this.
Old 06-08-2009, 06:44 PM
_Adam_'s Avatar
On my '07, if the doors are locked, and I open one of them, it automatically unlocks all of the doors. Is yours different?
Old 06-08-2009, 06:49 PM
mikmaze's Avatar
yup, 04.5 the only door that unlocks is the one you go out.
Old 06-09-2009, 06:04 AM
mini14's Avatar
all door unlock is a feature on the 4.5 u just have to program it. you have to make sure though that you turn the key off befor you open the door.
Old 06-09-2009, 12:13 PM
ssandlin's Avatar
On my 06 the auto lock feature can be disabled, instructions are in the manual, if I remember right. So, maybe check your owner's manual?
Old 06-10-2009, 05:36 AM
12 flapper's Avatar
I went to the dealer with my 03 and they disabled it, that stupid lock system would get me mad. I'd go to get the kid out of the passenger side realize the door is locked and my keys are still in the truck walk back around to the drviers door and unlock everything and then walk back to get the kid out. but everything is good now
Old 06-10-2009, 11:22 AM
Peterbilt's Avatar
I think they lock at 14mph. Check your owners guide. I believe it gives you a procedure to disable it.
Pete
Old 06-10-2009, 11:43 AM
05 CTD2500's Avatar
yes it is in the owners manual, as well as other neat features like disabling the seat belt chime and the horn chirp.
Old 06-11-2009, 02:24 PM
FMB
FMB's Avatar
Q. How many times do you have to do a double trip to open the passenger side door before you learn to unlock all the doors before you get out of the truck?
A. I'm not sure exactly how many times (I'm not there yet) but I'm darn sure it is over 1,000 times...
Old 06-12-2009, 09:48 AM
Belgrath04's Avatar
For an 07:
STANDARD PROCEDURE - RKE TRANSMITTER CUSTOMER PREFERENCES
AUTOMATIC (ROLLING) LOCKS
The rolling locks feature can be toggled ON/OFF by using a scan tool only.
HORN CHIRP DISABLING / ENABLING
The horn chirp can be toggled using a scan or by using the Remote Keyless Entry (RKE) transmitter that is already programmed to the vehicle.
To DISABLE (cancel) the horn chirp feature:
1. Enter the vehicle and close all doors.
2. Fasten the seat belt (this will cancel the seat belt chime).
3. Turn the ignition to the ON position.
4. Press and hold the LOCK button for 4 seconds. Within 6 seconds with the LOCK button still depressed, press the UNLOCK button. When a single chime is heard, release both buttons.
5. Turn the ignition OFF.
6. Turn the ignition ON or wait 60 seconds.
7. Test the horn chirp feature by pressing the LOCK button.
If a chime is not heard, program mode was canceled before the feature could be disabled. If necessary, repeat the procedure.
To ENABLE the horn chirp feature, repeat the above procedure.
OPTICAL CHIRP (FLASH) DISABLING / ENABLING
The optical chirp can be toggled using a scan tool or by using the Remote Keyless Entry (RKE) transmitter that is already programmed to the vehicle.
To DISABLE (cancel) the optical chirp feature:
4. Press and hold the LOCK button for 4 seconds. Within 6 seconds with the LOCK button still depressed, press the PANIC button. When a single chime is heard, release both buttons.
7. Test the optical chirp feature by pressing the LOCK button.
To ENABLE the optical chirp feature, repeat the above procedure.
UNLOCK SEQUENCE
The unlock sequence can be toggled using a scan tool or by using the Remote Keyless Entry (RKE) transmitter that is already programmed to the vehicle.
To toggle between Driver door first and Unlock all doors function:
4. Press and hold the UNLOCK button for 4 seconds. Within 6 seconds with the UNLOCK button still depressed, press the LOCK button. When a single chime is heard, release both buttons.
To toggle this feature, repeat the above procedure.
Old 06-12-2009, 01:13 PM
capnp72's Avatar
I disabled the door lock and seat belt chime on my '05 by simply following the instructions in the owner's manual. I like the horn chirp. It lets me know the truck is locked.
Old 06-12-2009, 02:15 PM
STate's Avatar
Up, Up, down, down, left, right, left, right, B, A, select, start!!!
Sorry I couldnt help myself!! Balgrath posted it before me! Hope it helps.
Scott
Old 06-12-2009, 07:02 PM
jdwest's Avatar
Scott
Awesome...haven't heard this in years! Good old Contra...
nomad65
08-20-2007 06:01 PM
ptm600
12-30-2005 11:11 AM
Commatoze
04-22-2005 07:45 AM
jrs_dodge_diesel
16
03-10-2004 11:15 PM
xj2extreme
11-26-2003 07:24 AM
Quick Reply: disable auto door locks ?
