Dirty Oil
Old 11-02-2009, 08:13 AM
Undertaker's Avatar
Dirty Oil
Why is it 2 days after changing my oil in my 2007 Cummins 5.9 the oil looks dirty already?
Old 11-02-2009, 08:15 AM
Danavilla's Avatar
Typical with 3rd gen engines. Has to do with injection events for smog control.
Old 11-02-2009, 08:29 AM
Texan1983's Avatar
typical with any diesel engine.
Old 11-02-2009, 09:50 AM
psd1's Avatar
I'll bet it didnt take two days to get that color...
Old 11-02-2009, 01:03 PM
Lost Lake's Avatar
2 days??? Mine is dirty after the warm up to check the oil level once I've changed it.
It's a diesel. Diesels have lots of soot. Pretty normal.
Old 11-02-2009, 03:10 PM
rockcrawler304's Avatar
Same here.
The 2004's and down are not as dirty but 04.5 and up get dirty right away. It is normal though.
Old 11-02-2009, 05:58 PM
Pikeman's Avatar
Dirty isnt bad. Isnt 15w40 black in the jugs??
Old 11-02-2009, 07:58 PM
05 Ram 3500 SRW's Avatar
they should pin this thread at the top. someone asks this question about every 10 days on here. nothing wrong with that though. it would just save starting new threads.
so the dirtier oil doesnt wear these engines out sooner?
dads older Ford stays really clean. we've always changed it at 5000kms though. thats not very many miles
Old 11-02-2009, 09:17 PM
CoastalDav's Avatar
Not true. My previous truck a 2000 3500 Cummins would run for 4000 miles before the oil started to turn dark. Up until then, you could see right thru it on the dip stick.
My 06 as stated, turns black right after the oil change at start up. Dodge and Cummins talk about dusting the engine, they should consider what's going on in the pan and the accumalation of soot and carbon.
If the 3rd injection event (EGR) is causing the problem, and the rings are not holding it, allowing soot and carbon to enter the pan, they have a problem with the rings and wear, as far as I'm concerned. This may cause compression problems down the road.
Dave
Old 11-03-2009, 09:58 AM
Lost Lake's Avatar
Well they are breaking a lot of rings in the '06's.... Hope my Smarty puts an end to that...
Old 11-03-2009, 04:47 PM
slimpicken's Avatar
Mine stays clean for a pretty good while. Weeks with over a hundred miles a day 6 days a week.
Old 11-03-2009, 06:14 PM
Spooler's Avatar
As stated above, The 03' and 04' trucks are no where near as bad as the 04.5 and up trucks.
raven392003
13
07-02-2007 06:52 PM
03CumminZ4X4
18
02-22-2006 11:04 PM
ArcticWolf
08-16-2005 12:11 AM
wadem
03-05-2005 03:19 PM
wadem
02-17-2005 09:27 AM
Quick Reply: Dirty Oil
