DiPricolTrans Gauge Help
Installed my gauges I had removed from my 03 into my04.5 and the trans temp gauge directions were no where to be found. So,the "B" terminal got connected to the switched 12vdc and the "T" terminal is ran to the sensor . Ground is to chassis of course. The needle movement appears erratic at times and may fluctuate about 50 degrees . Did I hook it up in reverse or do I have a bad connection ????????????????????? Any help will be appreciated.
Mark T.
Mark T.
Almost sounds like you gauge wire is grounding out somewhere. All the connections appear to be correct, at least that's how mine hooked up and worked. Possibly a bad sender as well.
jmccart
15
01-26-2008 09:32 PM
jmccart
01-26-2008 07:36 PM
Greeds22
25
09-11-2005 03:13 PM
engcogod
17
02-03-2005 08:49 PM
Patriot_RAM
10-08-2004 06:10 PM
