DiPricol Fuel Line
Old 01-03-2008, 12:37 AM
Pinksa's Avatar
DiPricol Fuel Line
Ive had my Dipricols for about 6 months now and the fuel line keeps bursting. Once under the hood, and the second under the dash. A buddy had the same problem?? Is there another type of turbing that will actually last??
Old 01-03-2008, 02:12 AM
trik396's Avatar
I suggest not using a mechanical fuel pressure guage and definately NOT running fuel into your truck. I run an electric guage and sender. More money, but it's worth it cause I don't get the hassles you just mentioned. Plus no isolator to mess with even if you went that route.
Old 01-03-2008, 12:45 PM
Pinksa's Avatar
Im starting to learn that. But the autometer fuel press wont match my Dipricol. Any other option??
Old 01-03-2008, 12:50 PM
06CTDforAU's Avatar
DiPricol has electric pressure gauges don't they?
Old 01-03-2008, 12:51 PM
Pinksa's Avatar
Well i just got off the phone with them, and they said they did. Im waiting for them to call me back
They do have the Electric, for $215 MSRP
Old 01-03-2008, 02:16 PM
chrigu's Avatar
hi
i have also dipricol fuel pressure gauges with fuel isolater, when the line burst i have no fuel in my truck.
i have no problem with this.
chris
Old 01-03-2008, 02:43 PM
oldmandan-1's Avatar
I am using 1/8" copper tubing on my dipricol mechanical gauge....no problems.
Should be able to find tubing most anywhere, I got mine at NAPA.
The same ferrells and fittings that work on plastic will work on copper tubing.
Old 01-03-2008, 10:19 PM
blcoonrod's Avatar
Yep I run copper into the cab also. No problems yet running 20 to 25psi.
Old 01-04-2008, 12:02 AM
trik396's Avatar
Copper is probably fine... but to me it's too soft and vibrations may cause wear that can cause a split in the line. IF, and that's a mighty big IF, I were to run fuel into my rig, I'd use a high pressure hydraulic line with pressed on fittings. Then I'd feel safe...
Fishjager
04-12-2007 08:58 PM
K2Cummins
04-28-2004 12:39 AM
RKCRWLR
01-14-2004 12:16 AM
Hired Gun
06-01-2003 08:12 AM
HeberRam
04-23-2003 02:05 AM
Quick Reply: DiPricol Fuel Line
