dimming lights
dimming lights
When I start my truck cold for the first 5 minutes something cycles on and off which causes the all the lights to dim and the voltmeter to drop down below the "safe" line. Any Ideas?
Mine does the same thing. I need some help here, also when I start it up it is around the 12 volt mark, then i cycles up and down. But it happens when I drive as well, even when I am cruising down the highway, my lights flicker. Had the alternator rebuilt because I thought that was the problem, but it keeps doing it. Could use some advice as well. Thanks.
_________________
'97 4x4, #100 plate, auto, DTT tranny, 168k, kdp soon do be dead...
_________________
It's your grid heater, everyone's does it. Go to the help forum and read the first post. I plug mine in when it's below 40 for about three hours (I have a timer) and the grid heater only cycles maybe once. By the way it's not a problem.
Wilderness, I plug mine in all night, I live in Idaho. It gets pretty cold at night the other night it got down to 12, but the problem is that mine cycles 5-6 times at least, but then it starts to flicker as I am rolling down the road..
_________
_________
_________
_________
Always does it, no matter how long I run the truck, I went 3 hours and it still did it.. Don't know what else is wrong.
_____________
_____________
The relay for the grid heater could be bad. Mine flickers for a bit but then levels off. I don't know what gives the heater the signal to kick on, if it's the temp sensor or the pcm? I would bet that it has something to do with the heater or the grounds. A bad ground does strange things.
Hey Wilderness, I checked all the grounds and they are cleaned and grounded. But the lights are still flickering the same. Any other suggestions?
______________
'97 4x4, #100 plate, auto, DTT tranny, 168k, kdp soon do be dead...New 4" exhaust, and cold air intake...Guages, EGT only, Boost is next.
______________
______________
______________
Was your truck running like this before the cold snap?
Nope it ran great.
________________
________________
Check your batteries before you start your truck. If they are below 12.5 volts you need one of these to perk them up. Regular battery charger don't work.
http://www.vdcelectronics.com/
mainehunter
11-24-2004 12:22 AM
Shovelhead
12-24-2003 03:35 PM
Tob
19
02-27-2003 08:04 AM
