Digital monitoring
Old 07-20-2009, 10:50 AM
1generationkid's Avatar
Digital monitoring
I am buying a smarty and was wondering if there was an monitor out there that i could use to monitor my system. I did have a predator programmer and loved how you could view live data. I was informed that the smarty POD does not have this option. Is there any type of digital monitor out there that i could use to view the live data. Any information would be helpful.
Old 07-20-2009, 12:43 PM
cwgtex's Avatar
Read up on the Quadzilla Commander or Scout, both are standalone systems.
http://www.thoroughbreddiesel.com/qu.../commander.htm
http://www.thoroughbreddiesel.com/quadzilla/scout.htm
Old 07-20-2009, 12:45 PM
BigJohnston's Avatar
The edge insight or the Quadzilla scout will give you a nice set of digital gauges. I went with the Quadzilla Commander(pre scout and pulse) because I can also change power levels on my Quad X2.
Old 07-20-2009, 02:28 PM
TX_Diesel's Avatar
I had the commander with my first mega cab and it worked flawlessly. With my 2nd mega I went with the Scout as it has a ton more features and gauges.
Both are great products. Keep in mind with the Scout you wouldn't have to purchase a RP gauge as with the Commander you would. The Scout (as you can read from above link) stays plugged into the OBD2 port all the time so it reports pretty much everything your computer sees..
Good luck!
kris55
01-13-2008 10:06 PM
timcasbolt
04-09-2006 07:02 PM
gdh11
05-17-2005 02:49 AM
Casey Balvert
10-11-2004 11:24 AM
trailblazenyj
06-08-2003 05:31 AM
Quick Reply: Digital monitoring
