Differential Fluid
Old 11-21-2009, 09:49 PM
rammer123's Avatar
Differential Fluid
I have a '05 Ram 2500, I want to change the Differential Fluid. I was just in the parts store they had Mobil 1 Full Synthetic 75w 90. (on the front label it said LS) But on the back label it said meets GL-5. Is this good for my truck.
Old 11-21-2009, 10:00 PM
dozer12216's Avatar
Yes, it good. LS is special additive to GL-5 spec fluid. If has the AAM(?, not the Dana 70-80) axle it not need LS. Check again
Old 11-22-2009, 02:23 AM
TexasCTD's Avatar
I have been running Mobil 1 75w90 GL-5 synthetic gear oil in my diffs for the past 110K miles with no problems. Good stuff. I change out every 20K miles now...which is probably overkill.
Old 11-22-2009, 08:51 AM
DirtEater's Avatar
The Mobil1 is a bargain compared to the others right now. I've seen Royal Purple for as much as $19.99. When I used it, 20,000 miles ago, I think I paid $11. I won't buy it next time, not at those prices, and will most likely give Mobil1 a try.
Old 11-22-2009, 10:56 AM
ChrisJohnson's Avatar
I use Redline myself, and order it through JEGS.
Old 11-24-2009, 05:48 PM
big-c's Avatar
is mobile 1 good for the tranny also
Old 11-24-2009, 06:04 PM
ripping r's Avatar
mobile 1 here to. but i go 30,000 on changes in the rear. with the mag. still doing the front at 15,000. untell i get a mag up there
Old 11-25-2009, 11:24 PM
stickk's Avatar
If you have the G56 it calls for atf+4 synthetic. Don't know about the previous manuals.
coobie
11-29-2004 04:26 PM
wilnis
09-17-2004 12:33 PM
eswartz
09-16-2004 06:52 AM
L. D. Bryant
03-22-2004 03:14 PM
BADodge2003
08-06-2003 09:43 PM
Quick Reply: Differential Fluid
