Difference in VINs? (concerning engine)
Hey Guys...
In my searching for a new to me truck(2003 or 2004), I have noticed two different VIN characters for a Cummins. In position 8, either a "C" or a "6" denotes the diesel engine. So my question for you guys, is whats the difference, if any, in those engines?
It seems like I have seen both digits in both years...but i can only confirm both in 2003 at the moment.
Thanks for all your help!
Scott
Scott
ah, ok, cool. So.....which one do i want? lol
Seriously though....whats the difference in the HO and Standard? Does one get better mileage, or is one coupled to a different tranny? Is one more generally desired than the other??
The only difference that I can think of is a truck with a 6 in position 8 could have the 47 or 48re transmission in it depending on when it was built, this would be only for the 03's if I remember correctly.
I copied and pasted this from another thread:
VIN POSITION INTERPRETATION CODE = DESCRIPTION
1 Country of Origin
...1 = Manufactured By DaimlerChrysler Corporation
...3 = Manufactured By DaimlerChrysler De Mexico
2 Make D = Dodge
3 Vehicle Type
...2 = Incomplete with Side Airbag
...3 = Truck with Side Airbag
...6 = Incomplete Less Side Airbag
...7 = Truck Less Side Airbag
4 Gross Vehicle Weight Rating
...G = 5,001-6000 lbs.
...H = 6,001-7,000 lbs.
...J = 7,001-8,000 lbs.
...K = 8,001-9,000 lbs.
...L = 9,001-10,000 lbs.
...M = 10,001-14,000 lbs.
...W = Buses/Incomplete Vehicles with Hydraulic Brakes
5 Vehicle Line
...A = Ram Pickup 4X2
...U = Ram Pickup 4X4
6 Series
...1 = 1500
...2 = 2500
...3 = 3500 Less Dual Rear Wheels
...4 = 3500 With Dual Rear Wheels
7 Body Style
...6 = Conventional Cab
...8 = Quad Cab Full Rear Doors
8 Engine
...K = 3.7L 6 cyl. MPI Gasoline
...N = 4.7L 8 cyl. MPI Gasoline
...D = 5.7L 8 cyl. SMPI Gasoline
...6 = 5.9L 6 cyl. Turbo Diesel
...C = 5.9L 6 cyl. Turbo Diesel High Output
...W = 8.0L 10 cyl. MPI Gasoline
...Z = 5.9L 8 cyl. SMPI Gasoline Light Duty
9 Check Digit 0 through 9 or X
10 Model Year 3 = 2003
11 Plant Location
...S = Dodge City
...G = Saltillo
...J = St. Louis (North)
12 thru 17 Vehicle Build Sequence
1 Country of Origin
2 Make D = Dodge
3 Vehicle Type
5 Vehicle Line
6 Series
...1 = 1500
...2 = 2500
7 Body Style
8 Engine
11 Plant Location
...S = Dodge City
...G = Saltillo
lol.....think a salesman would look at me weird if i went to him and said, i would like a truck that matches first part of the Vin:
xD7KU28C
so what HP does the standard motor have? anybody know? and is there a down side to the 47RE vs. the 48RE?
xD7KU28C
just found this in another post:
So if i am reading this correctly, and i find a 2003 auto C vin, that means it would be a 48RE, and if its an 03 auto 6 vin, then it would be a 47RE? Is that right?
Another thing I can't figure out from searching, is which one is better? Is there one that is better/more reliable than the other?
Thanks again for all the help, guys!
2003 S.O. Federal Emissions: 250HP/460lb.ft. Available with NV4500 or 47RE
2003 S.O. Calif. Emissions: 235HP/460lb.ft. Available with NV4500 or 47RE
2003 H.O. Federal Emissions: 305HP/555lb.ft. Only available with NV5600
2003.5 The 47RE was replaced by the 48RE automatic transmission and available with the H.O.
2004 S.O. Calif. Emissions: 235HP/460lb.ft. Available with NV4500 or 48RE
2004 H.O. Federal Emissions: 305HP/555lb.ft. Available with either NV5600 or 48RE
DTR's 'Go to Guy'
The 48 is basically an updated version of the 47. Better in my opinion. More clutches per drum and better shifting overall IMO. The SO has 250hp and the HO was 305 .
sold it
24
08-28-2009 07:25 PM
06CTDforAU
08-19-2008 11:05 PM
GotPub
06-05-2008 09:34 AM
precision1
02-16-2008 12:48 PM
