Difference between Coolant Temp. Sensor/Sender?
Old Sep 21, 2010 | 03:24 PM
ARbowhunter7's Avatar
My coolant temp guage does not work at all, just sits there. I am trying to order a replacement from rock-auto.com. They have a coolant temperature sensor AND a coolant temperature sender, both of which look identical. One is around $10 bucks, the other is $40. I know that one goes directly to the gauge from the driver's side of the head, and the other one goes to the engine's computer. Which one do I need for a dead gauge?
Old Sep 22, 2010 | 06:02 PM
Jim5870's Avatar
This the sensor near the fuel filter
This is the temp sensor at the back of the head
Which is the PCM sensor and which is the guage sender?
Old Sep 22, 2010 | 06:23 PM
PCM sensor is near the filter, it is only on automatic trucks.
Old Feb 9, 2011 | 08:50 PM
brandon mitchel's Avatar
The coolant temperature sensor is located at the head near the thermostat. It controls when the engine enters closed loop and turning on the radiator fan.
Old Feb 9, 2011 | 09:33 PM
BC847's Avatar
1st Generation Admin
We don't have a "Closed Loop" system nor an electrically controlled fan.
And the temperature sensor for the Gauge is located at the rear of the head as is shown above.
These are the 1st gen Cummins diesel engines (Bosch rotary VE injection pump).
Old Feb 9, 2011 | 11:56 PM
fatt's Avatar
So what is the plug near the fuel filter for?
Old Feb 10, 2011 | 09:07 AM
BC847's Avatar
It tells the PCM when the engine is warm and it can then engage overdrive.
Tater93
Jun 20, 2011 09:43 PM
Exekiel69
Cummins Conversions
Sep 27, 2008 07:32 PM
Tacsavage
Dec 26, 2007 05:30 PM
Cam73
Dec 10, 2006 05:54 PM
ralphdogg
Nov 13, 2006 04:22 PM
