Diff Cover Drains
Old 09-28-2005, 11:28 PM
triplenickel's Avatar
Diff Cover Drains
Has anyone drilled and tapped the stock diff covers to make service easier? Are they thick enough to get a couple of threads in, if not could a guy weld in a 1/4" NPT weldlet without warping the cover?
Old 09-30-2005, 08:57 PM
Any thoughts?
Old 09-30-2005, 10:48 PM
Hal
Hal's Avatar
Drill and install an aftermarket B&M transmission plug? Might work, but I haven't tried...
Old 10-03-2005, 09:21 PM
TonyB's Avatar
Don't recall the site....PML (sp?) looks like a good cover w/ drain & fill plugs.
I prefer the Mag-Hytec covers. All O-ring seals, even the mounting face. Drain plug, sight (level plug), fill plug/dipstick, and even a port for an 1/8" temp sending unit.
Not a salesman....just a satified customer. Have one on my F150 and on the Dak. Maintenance couldn't be easier.
HTH
Tony
Old 10-03-2005, 09:40 PM
dodgezilla04's Avatar
you can get drain plugs that are 2 piece, drill a hole and one piece threads into the other from both sides of the cover, sort of like a compression fitting, got mine for a blazer from napa, they were B & M
Old 10-04-2005, 11:06 AM
zog
zog's Avatar
The B&M drain plug sounds like a great idea....as long as it does not interfere with the ring gear...I don't have posi so I am going to give it a try...I'll let you know.
Old 10-04-2005, 11:32 PM
the inside sealing nut protrudes less than 1/2" into the rear end. place it off center(away from the ring gear) and no worrries.
Mexstan
09-17-2010 08:03 AM
Chillimau
08-11-2008 09:24 AM
archer2
10-11-2007 11:05 AM
Bueller
07-08-2006 10:47 AM
yebatza
03-26-2006 05:24 PM
Quick Reply: Diff Cover Drains
