Diff and Xfer case fluids
Here's what Dodge says:
DESCRIPTION - TRANSFER CASE
Recommended lubricant for the NV241 GENII,
NV271, NV243, NV244 GENII, and NV273 transfer
cases is Mopart ATF +4, Automatic Transmission
Fluid.
TRANSFER CASE
NV241 GENII 1.6 L (3.4 pts.)
NV243 1.6 L (3.4 pts.)
NV244 GENII 1.6 L (3.4 pts.)
NV271 1.89 L (4.0 pts.)
NV273 1.89 L (4.0 pts.)
FRONT AXLE
² C205F - Mopart Gear Lubricant 75W-90
² 9 1/4 AA - Mopart Synthetic Gear Lubricant
75W-90
REAR AXLE
² 9 1/4 - Mopart Synthetic Gear Lubricant 75W-
140
² 10 1/2 AA - Mopart Synthetic Gear Lubricant
75W-90
² 11 1/2 AA - Mopart Synthetic Gear Lubricant
75W-90
NOTE: Trac-LokT differentials require Limited Slip
Additive in the lubricant. Trac-Rite™ differentials
DO NOT require Limited Slip Additive.
FRONT AXLE ± .03 L (1 oz)
C205F 1.66 L (3.5 pts.)
9 1/4 AA 2.25 L (4.75 pts.)
REAR AXLE ± .03 L (1 oz)
9 1/4 2.32 L (4.9 pts.)***
10 1/2 AA 2.25 L (4.75 pts.)
11 1/2 AA 3.62 L (7.65 pts)
*** With Trac-Lok add 118 ml (4 oz.) of Limited Slip
Additive.
*Nominal refill capacities are shown. A variation may
be observed from vehicle to vehicle due to
manufacturing tolerance and refill procedure.
I fill mine till it overflows out of the hole.
HTH...
mad
Fluid.
TRANSFER CASE
FRONT AXLE
75W-90
REAR AXLE
140
75W-90
75W-90
Additive.
HTH...
mad
Fluid.
TRANSFER CASE
FRONT AXLE
75W-90
REAR AXLE
140
75W-90
75W-90
Additive.
HTH...
mad
Fluid.
TRANSFER CASE
FRONT AXLE
75W-90
REAR AXLE
140
75W-90
75W-90
Additive.
HTH...
mad
The anti-slip in ours is said not to require limited slip additive. I talked with a guy at Redline about whether I needed their NS (no limited slip). He said this application doesn't need the additive, but running the regular stuff with additive wouldn't hurt anything, and is actually more slippery.
On some of the rear covers there's "fill level" and a line stamped in the cover, around 3/4" below the bottom of the fill hole.
Also, although the book calls for 30 ft/lbs cover bolts and 24 drain plug, I don't run mine that tight. There have been several threads about breaking the bolt.
Also, the gasket is reuseable.
4x4dually
Jun 20, 2006 08:38 AM
guidster
Jun 6, 2005 11:16 AM
